It is currently Wed Jul 16, 2025 1:28 pm
Reply to topic  [ 11 posts ]
 shaft stuck on u-joint
Post shaft stuck on u-joint
My upper seals on my LT are out an i tried changin them put i cant get the shaft out of the u-joint! I even tried heating up the outside of the u-joint but no luck! Any suggestion on this??
Mon Mar 15, 2010 6:30 pm
Post Re: shaft stuck on u-joint
You can rent a slide hammer bearing puller or axle puller(whatever it is) from autozone for free. That's what I have used with good results...
Mon Mar 15, 2010 6:59 pm
Mon Mar 15, 2010 7:01 pm
Mon Mar 15, 2010 7:09 pm
Had same problem.
Heated it with blow torch. Came right off.
You might try heat again and make sure you get it hot...
Mon Mar 15, 2010 7:17 pm
Mon Mar 15, 2010 8:24 pm
You aren't gonna get it hot enough with propane. Go with oxy-acetylene.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Tue Mar 16, 2010 5:00 am
Tue Mar 16, 2010 5:55 am
I use a long tapered punch. Drive the punch between the u joint and the shaft. The wedge shape will force the u Joint off. When you run out of shaft to push on remove the wedge and place a nut that fit in the shaft opening on the ujoint. This will drive the ujoint the rest of the way. Your other option is to dissamble the ujoint by removing the clips on the inside ofthe ujoint pins.
Tue Mar 16, 2010 7:06 am
just bring it by the shop jackass!!!!1 and we wil get it off.. and no im not coming pick the boat up.. :lol: :lol:
BUNDY BUILT SKIFFLESS
cuz der bad ass like dat....
bunnny rabbit customs.
Tue Mar 16, 2010 8:05 am
slide hammer works the best. just put a spacer between the u-joint and shaft housing so your not hammering against the motor shaft
ETD88 09/28/09-05/14/2010...
Tue Mar 16, 2010 8:47 am
Users browsing this forum: No registered users and 66 guests
