It is currently Wed Jun 25, 2025 5:16 am
[ 6 posts ] |
different kind of a problem
playhard11
any one ever had the problem of their pup burying live birds? my 7 month old puppy is working very well with bumbers, but when i use live birds for training he runs off and buries them...having a hard time breaking him of this...any suggestions...
Tue Jun 19, 2012 11:38 am |
KwickLabs
 Re: different kind of a problem
_________________ http://www.kwicklabs.com
Wed Jun 20, 2012 4:15 pm |
Duckdon
Joined: Sat Apr 24, 2010 3:32 pm Posts: 407 Location: Chugiak, Alaska
Adding to Kwiklab I would agree and I would work hard on the Ob. Move to the check cord and when your pup know's "here" then add in the e-collar. Call him in by name and "Here" and give a slite tug on the check cord at the same time you apply continous light e pressure. Use the continous mode on as light a setting as you can to see a reaction. As soon as he turns toward you, he makes eye contact and he starts in to you, let off the e pressure. As soon as he looses eye contact, starts off in another direction, runs past you........any indication he is not still coming directly in, lay on the e pressure again repeating his "name" and "here" command until he is again coming in. TIMING is everything...... He will get it in 10 minutes if your timing is spot on. Then lots of repeated drills in lots of different places. REMEMBER TIMING WITH THE E-COLLAR IS WHAT MAKES IT WORK CAUSE THEY LEARN HOW TO TURN OFF THE PRESSURE WITH COMPLIANCE but first they need to know the command. The nick or buzzer mode has little value in my opinion. Lay on the e pressure as lightly as needed and keep the finger on the button until he responds correctly then off the button. Good luck and remember never train when your upset or drunk. He will get it if you explain it to him correctly.......Duckdon
Thu Jun 21, 2012 8:33 am |
playhard11
guys , thanks for the response, yall were spot on with "here" command, normally he is good with it, but it isnt automatic, i will definetly work on it more....thanks for the help, i really wanted to make sure there wasnt something else going on here i wasnt aware of, but it sounds like a simple fix
Fri Jun 22, 2012 3:11 pm |
MNGunner
Joined: Mon Jan 09, 2012 8:56 pm Posts: 2623 Location: Minnesota
Check cords are also a great way to solve your problem. As always, make sure they understand the command before using the e-collar--it is a tool to reinforce commands NOT teach them!
_________________ 1754 Gator Trax Hybrid Hunt Deck with GTR35
Sat Jun 23, 2012 6:42 pm |
The Shafer
Joined: Tue Jan 13, 2009 7:46 pm Posts: 1947 Location: Longview. TX
X2 on check cords!!!
_________________ WC 1848 Bateau w/ 36 PD FPR
Sat Jun 23, 2012 10:08 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 37 guests |
