Tenpoint
Joined: Thu Aug 27, 2009 5:22 pm Posts: 2029 Location: Patterson LA
 Aviation fuel
Anybody run av gas in their mudmotor? I had a couple gallons left over from my airboat so I dumped it in the GTR tank. I probably had about 6 gallons in my 10 gallon tank when I added the av gas. I know the av gas is leaded so I dont know if doing this often would hurt anything. It sure smells good though. Let me know some thoughts on the situation.
_________________ 19x48 Rink/Aucoin Bateau w/35 GTR 20x60 Home-made skiff w/200 Merc
Wed Jun 30, 2010 7:48 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
 Re: Aviation fuel
You'll be fine.
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
Wed Jun 30, 2010 7:50 pm |
quackconsumer
 Re: Aviation fuel
You'll be able to gain altitude quicker.
Wed Jun 30, 2010 7:52 pm |
Tenpoint
 Re: Aviation fuel
Wed Jun 30, 2010 7:53 pm |
brlcla
Joined: Tue Jan 13, 2009 5:11 pm Posts: 955 Location: Lake Charles, LA
 Re: Aviation fuel
the av gas should also be unleaded... and you will run a little rich...
Wed Jun 30, 2010 7:59 pm |
Gatorpoint
Joined: Tue Jan 13, 2009 8:09 pm Posts: 1175 Location: A slough behind you, TEXAS
 Re: Aviation fuel
Thats all i run in mine. It does run a little rich.
_________________ 1854 Brotha Breaux Bateau pullin' a 35 GT arrrrahhh! Willett Welding custom boat trailer
Wed Jun 30, 2010 8:00 pm |
Tenpoint
 Re: Aviation fuel
Wed Jun 30, 2010 8:01 pm |
brlcla
 Re: Aviation fuel
well damn learned something new....
Wed Jun 30, 2010 8:09 pm |
UNCLE-J
Joined: Fri Jul 24, 2009 7:26 am Posts: 10388 Location: S-Ville, LA
 Re: Aviation fuel
Why would you waste AV Gas in a MM when you have a Airboat that needs it?
Wed Jun 30, 2010 9:37 pm |
basinlover
Joined: Mon Mar 09, 2009 12:24 pm Posts: 279 Location: DE Jeanerette, LA.
 Re: Aviation fuel
Also works great in all your two-stroke engines like chainsaws , weedeaters etc, it doesn't break down and varnish clogging carbs and will not eat rubber hoses like ethanol, has about a two year shelf life versus about a month for pump crap only problem it evaporates very quickly. I run it in all my stuff that I don't use often only about 30 cents more than SU around Franklin LA.
_________________ There is no replacement for displacement!!!!
Wed Jun 30, 2010 9:52 pm |
tongthrower
Joined: Wed Jan 14, 2009 8:36 am Posts: 672 Location: Houston, TX
 Re: Aviation fuel
i ran 100LL in my 2000 Silverado a few times and had no problem with it. Had to pull 5 gallons a day out of the sump and just made sure there was no water or dirt in it.
_________________ EVT Stage 1 32PD on a 17x48PD "I'm not a Republican because I grew up rich. I'm a Republican because I did'nt want to spend the rest of my life poor. Waiting for the goverment to rescue me." Mike Huckabee
Thu Jul 01, 2010 1:50 am |
Gatorpoint
 Re: Aviation fuel
Thu Jul 01, 2010 6:10 am |
drake1
 Re: Aviation fuel
U will be fine running it. I run it in my polaris ranger, GTR, weedeater and echo blower. As far as running straight AV gas you really need a high compression motor or a bit more timing advance. AV gas has a slow burn rate so if you are not hot on your spark it tends to leave alot of lead deposits in the exhaust ports, combustion chamber and on top of the pistons and valves. It was pretty scary when I did my first plug check on the AV gas and the plugs were grey  . Actually the color should be grey to light grey on the plug when running AV.
Thu Jul 01, 2010 6:26 am |
