It is currently Tue Dec 16, 2025 12:21 pm
Reply to topic  [ 29 posts ]
 PROS & CONS
Post PROS & CONS
I just ordered an Uncle J custom should I 45 the bottom of the stearn or leave it flat??? The boat is gonna be 18X48 with a Pro Drive. :!: :!: :!: :!: :!:
Wed Dec 08, 2010 7:42 am
Post Re: PROS & CONS
Someone give some opinions.. I need an answer from Flatboat !!!
Wed Dec 08, 2010 8:55 am
If you're puttin a PD on it don't 45 it. If you were puttin a GTR on it then you would have to weigh da pros and cons, but wit any other MM it is better not to 45 it.
Wed Dec 08, 2010 9:26 am
No 45 for your PD, leave it flat like Uncle J's head. :D
Wed Dec 08, 2010 9:47 am
Wed Dec 08, 2010 9:52 am
I like mine with the 45, but you don't need it with the PD. So just go without so J can get finished, he's got chit to do. :lol:
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Dec 08, 2010 11:19 am
Had a long discussion last week with owner of Collette fabrication in Henderson about the 45 degree cut at the bottom/transom junction. He said it helped considerably to displace backwash in reverse and provided a bit of lift, as well. There was virtually no trade-off with planning efficiency. He personally uses a long tail. His experience with Pro Drive was that it was not practical in stumpy areas and that Gator Tail and the like had the best configuration for a surface drive as the prop sits well back of the transom compared to the Pro Drive allowing for the bottom of the boat to clear underwater obstacles permitting the prop to gain purchase again enough to provide one last thrust to carry it over the stump. His podnah had a Pro Drive for 2 weeks then sold it. He said he would have a Gator Tail if he had to make long runs, but his houseboat is only 500 feet from his blind. Just sayin.....
Wed Dec 08, 2010 12:35 pm
Personally, I find that if you have the 45, it enables the water to come off of the bottom of the boat to quick. meaning, that the prop is actually a bit too far back to cavitate correctley. I had a really light boat, with a 45 and couldnt get any good speeds. I put the motor on a Square back, and increase 4 mph.
just my .02
Wed Dec 08, 2010 12:38 pm
Wed Dec 08, 2010 12:51 pm
Seems to me most people agree no 45 with a Pro Drive so i guess I will go with the peer pressure and the 1st Venice Edition Uncle J will have a flat back Thanks for replies
Wed Dec 08, 2010 1:36 pm
If you are planning on backing up in mud,then 45 it ;)
Wed Dec 08, 2010 6:17 pm
Wed Dec 08, 2010 7:22 pm
17x48 extreme stage 2 GTR
Wed Dec 08, 2010 7:34 pm
Wed Dec 08, 2010 7:43 pm
Wed Dec 08, 2010 7:44 pm
Wed Dec 08, 2010 7:49 pm
Yes I'm new to the site but I have noticed one thing, If you mention that ProDrive runs, handles, etc... in any good manner, deltaduckmaster has to be NEGATIVE about them. I'm curious, why is this?
Wed Dec 08, 2010 11:06 pm
Wed Dec 08, 2010 11:16 pm
Thu Dec 09, 2010 8:52 am
Thu Dec 09, 2010 6:42 pm
DDM enjoys Kyles penis head massaging his tonsils
Thats why
Thu Dec 09, 2010 8:44 pm
Thu Dec 09, 2010 11:17 pm
Fri Dec 10, 2010 8:57 am
Fri Dec 10, 2010 10:10 am
Uncle Js ~ Why :shock: ???
Fri Dec 10, 2010 10:13 am
Trying to get my post count up..
Fri Dec 10, 2010 1:32 pm
OK .....
Me too .......
Fri Dec 10, 2010 1:33 pm
Fri Dec 10, 2010 1:35 pm
BROOKS
Thanks for the information, now I understand why some things happen the way they do. I must say by reading older threads on this site, You are the voice of reason and wisdom. Not taking away from any others that are very helpful. You are the philosopher of MMT, in my opinion. I enjoy reading your post.
Sat Dec 11, 2010 12:23 pm
