It is currently Wed Jul 16, 2025 12:14 pm
Reply to topic  [ 9 posts ]
 Longtail Finally Done !
Post Longtail Finally Done !
I just finished my Longtail tonight ran it in the driveway everything looked good all i gotta do is rig up the kill switch and put in the set screws on the upper bearing and drill a hole for the u joint screws. i do have a question about the lower prop washers where do they fit in the order of things right now i have the cap on then the machined prop nut then a washer then a prop then washer and then the 2 jam nuts im curious if the washers are right or if one goes between the machined nut and cap ?
17Foot Aquasport 85 Evinrude
20GDLT Looking for a Hull
Sat Jul 09, 2011 7:38 pm
You have it right.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Sat Jul 09, 2011 8:03 pm
Post Re: Longtail Finally Done !
so the two bronze washers go on either side of the prop it doesnt seem right for that machined prop nut to ride right on the cap like that i would think that there would need to be one there but like ie said i dont know which is right thanks for letting me know that i got it right so it wont hurt the cap having that machined prop nut riding right on it ?
Sun Jul 10, 2011 1:06 am
Went you set the shaft you need to allow about 1/8" clearance between the cap and nut.
Sun Jul 10, 2011 5:50 am
so dont tighten the nut to the cap well then what keeps the shaft tight in the housing ?
Sun Jul 10, 2011 11:49 am
bearings, the u-joint holds it from the top.
Sun Jul 10, 2011 12:14 pm
so its the same on yours woodie 1/8 inch between cap and nut can somebody post a pic for me to look at ?
Sun Jul 10, 2011 2:52 pm
The yoke and set screw is what holds the shaft in place.
Also, the top bearing with a concentric collar.
Sun Jul 10, 2011 6:57 pm
I'd say its a good bit more than 1/8 on mine.
Mon Jul 11, 2011 9:33 am
Users browsing this forum: No registered users and 52 guests
