It is currently Sun Jul 13, 2025 12:14 am
Reply to topic  [ 5 posts ]
 convert a go devil 16hp into a 35hp question (( plz help ))
Post convert a go devil 16hp into a 35hp question (( plz help ))
I picked up a running 16hp vanguard Go Devil for next to nothing last night i want to order a vanguard 35 to put in place of the 16hp will the longtail shaft work if i can out the prop. I looked on Go Devils web site and its a 72 inch tail and the 35 also can come in a 72. Im just not sure if it will swap out without beefing the tail up or not also if it will just bolt on.
Tue Mar 13, 2012 7:34 pm
Post Re: convert a go devil 16hp into a 35hp question (( plz help
the 35 mounting bolts holes is diffrent from the 16
Tue Mar 13, 2012 7:37 pm
You'll have to redrill your mounting holes change your your joint and also fro
3/4 to 7/8 shaft seals bushings bearings etc and don't forget the prop hope I didn't forget anything
Tue Mar 13, 2012 7:51 pm
ok thanks guys saved me a waste of money i guess the 16hp will have to due for now.
Tue Mar 13, 2012 7:53 pm
The two engines have different PTO heights, that would require major modifications for it to mount up.
Your balance would also be thrown way off.
A 23 hp Briggs would bolt right up and give you a noticeable increase in power.
Tue Mar 13, 2012 10:42 pm
Users browsing this forum: No registered users and 21 guests
