It is currently Thu Jul 17, 2025 4:19 pm
Reply to topic  [ 20 posts ]
 11 HP HOME BUILD
Post 11 HP HOME BUILD
I'M BUILDING AN 11 HP HONDA MAD MUD MOTOR, ANY SUGGESTIONS ON A GOOD ALL-AROUND SIZE PROP? 14X36 SEMI-V GRUMMAN BOAT WITH PODS ALMOST COMPLETE.
THE BEST THINGS IN LIFE HAPPEN IN THE FIELD, IN THE WOODS AND ON THE WATER.[color=#FF0000][/color]
Fri Mar 09, 2012 11:49 pm
Well tell you after you turn off the caps lock
Sat Mar 10, 2012 12:22 am
Post Re: 11 HP HOME BUILD
1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
Mon Mar 12, 2012 12:19 pm
Alright, the caps lock is off.
Mon Mar 12, 2012 8:29 pm
7X4 or 8X4 for 11 hp
1836 go devil, 23 hp LT go devil
Mon Mar 12, 2012 8:45 pm
Have any idea which is faster?
Tue Mar 13, 2012 4:24 pm
I'm assuming the 8x4.
Tue Mar 13, 2012 4:33 pm
1846 GTB and 35 GTR
New GT Rig
Thu Mar 15, 2012 7:06 am
The motor was given to me so that's what I have to go with. I'm also building pods for the back. Just have to finish welding them up.
Thu Mar 15, 2012 10:53 am
Are you building a long tail or a surface drive? That will determine what size prop you use.
1846 GTB and 35 GTR
New GT Rig
Thu Mar 15, 2012 1:30 pm
Longtail. Almost complete. I'm hoping the pods I designed and cut out will help. I based them off of Beavertails' pods. Well just see. I know longtails aren't fast, but here in Arkansas we dont deal with mud much. Mainly stumps, debris under the surface and logs in the flooded timber.
Fri Mar 16, 2012 3:48 pm
8x4 will be mint for that setup
B. MacDonald
Fri Mar 16, 2012 5:21 pm
X2 the 8x4 will work great.
1846 GTB and 35 GTR
New GT Rig
Fri Mar 16, 2012 6:52 pm
sftull, what makes you think my boat won't plane out. Just curious. Ive delt with outboards for as long as I can remember. Still a little green with the mud motors, but loving it. My project has rubbed off on my father in law. Now were talking about building him one.
Sat Mar 17, 2012 12:28 pm
11 hp in mudmotor isn't equal to 11 hp in outboard.
I had a 13 with a 1442 and it was a great one man rig, but add a second man and some decoys and it fell on it's face
Sat Mar 17, 2012 8:54 pm
Ill have to remember that. What hp engine would you recommend?
Mon Mar 19, 2012 5:29 am
If you want speed, then build a surface drive.
1846 GTB and 35 GTR
New GT Rig
Mon Mar 19, 2012 2:55 pm
How wide is your hull?
A 13 hp is the biggest single cylinder, after that there is a 14 hp briggs v-twin but if you decide to go with a v-twin get the 23 Briggs (same weight as 14)
Mon Mar 19, 2012 4:45 pm
My hull is 36". Maybe ill finish this one and build a bigger one. Thanks for the info.
Tue Mar 20, 2012 9:58 pm
Modern outboards rate hp at prop - your engine is rated at the shaft
outboards are in-line thrust with the hull - longtails are angled thrust
Johnson 9.9 may run a 10in. pitch prop - you are looking at a 4in. pitch prop.
Every revolution would theoretically move the prop 10 inches forward versus the 4 inches - that gives the outboard more than twice the distance covered for the same rpms
Outboards = fast in clean water
Longtails = torque advantage in soup
Your hull will have to achieve a certain speed under different loads to "plane". You can only go so fast with a 4in prop, but you will go with confidence.
Tue Jun 05, 2012 1:15 pm
Users browsing this forum: Google [Bot] and 52 guests
