It is currently Sun Jul 06, 2025 2:56 am
Reply to topic  [ 6 posts ]
 Replacing a GoDevil shaft
Post Replacing a GoDevil shaft
I have a 2000 kohler decided to replace the shaft. Ive taken the prop off and the nut assembly off unscrewed the set bolts on the lower yoke. Now how do i get the upper and lower housing assemblies off to install the new top bearing and replace the bushings and do i just beat the shit out of the prop till the shaft starts the move and then take the shaft key out. Pictures or videos would be helpful because i cant find anything useful on the internet.
Tue Oct 02, 2012 6:10 pm
Post Re: Replacing a GoDevil shaft
That would be about right. Hit the backside of the prop and the shaft will eventually work its way out of the yoke. Might want to try to put a flat head screwdriver in the slot of the yoke to loosen it up some.
The new shaft goes in the same way, beat it.
Wed Oct 03, 2012 10:52 am
a slide hammer is the correct application for this. ;)
17*38 Klibert 23GDLT
Wed Oct 03, 2012 10:57 am
Please download the service manual from the Godevil website. http://www.godevil.com/documents/Go-Dev ... Manual.pdf
Wed Oct 03, 2012 2:50 pm
Wed Oct 03, 2012 3:04 pm
Make sure to replace upper an lower seals, I did this an only replaced lower and it wouldn't keep grease for no longer than 5 minutes in the autoluber.
27 GDLT pushing a War Eagle 1542
Wed Oct 03, 2012 6:02 pm
Users browsing this forum: No registered users and 63 guests
