It is currently Sun Jul 20, 2025 5:31 pm
Reply to topic  [ 60 posts ]  Go to page 1, 2  Next
 17x54 GTB outboard size
Post 17x54 GTB outboard size
Anyone use a outboard after duck season to fish? Thinking I would like to go his route to save wear and tear on the GTR..
Sat Jan 05, 2013 6:07 pm
Post Re: 17x54 GTB outboard size
Buddy has a 90 Yamaha on his 1754 G3, I'm sure something similar would be fine.
Sent from my MB865 using Tapatalk 2
Sat Jan 05, 2013 6:27 pm
1754 GTB / 35 GTR
Sat Jan 05, 2013 7:38 pm
Buddy of mine has a 90 Yamaha on a 17 excel and it will haul ass! But bounces a lot
35 gtr pushing a beer can
Sat Jan 05, 2013 7:51 pm
Put a 60 on it.
Sat Jan 05, 2013 7:57 pm
60hp is exactly what I was thinking
Sat Jan 05, 2013 8:30 pm
Even a 40 would get you good
Sun Jan 06, 2013 2:48 am
Slap a 90 on it with a jack plate so you can eliminate the bounce and run prolly mid-upper 40s
Sun Jan 06, 2013 8:36 am
Nexty question will prolly spark the same battle as of GTR/Prodrive but what brand yall running?
Tue Jan 08, 2013 2:54 pm
I took the 35GTR off my last 1754 excel and put on a 60hp for a trip to Canada where I needed to run 20+ miles one way. It ran fine and pushed a heavy load. It turnd differently with the flat bottom and bounced if I turn sharper. I put the surface drive back on later that fall.
I wouldn't hesitate to do it again.
1854 Brother Breaux and Boss 40XP and 90hp outboard.
Tue Jan 08, 2013 4:02 pm
1754 GTB / 35 GTR
Tue Jan 08, 2013 5:11 pm
Thanks for the info guys.... im now looking for a 60hp outboard to buy... Let me know if you see something that comes up for sale
Fri Jan 11, 2013 10:40 am
I got a 2010 50 Merc yesterday 4 stroke. I wasnt to happy with the maiden voyage. The boat barley got out of its own way and on step. Top speed was around 28-29 mph. I know props size and pitch are everything when it comes to outboards but without having a tack im shooting in the dark.. I was really hoping to get HIGH 30's loaded down with this set up. I might have hoped for to much. Any ideas on prop size for this set up? I took a mesurment and I got 10" by 15 pitch. 15p is stamped on the prop. This is the prop that came with the motor. If I cant get it right ill just sell being I got it for a great price and its a super clean motor
Sat Jan 26, 2013 8:39 am
Sat Jan 26, 2013 8:48 am
Sat Jan 26, 2013 8:51 am
That's a fact! I had a 16x60 welded bateau with 24" sides with a 75 evinrude at one time and I was lucky to get anything over 35 in it, and that was with a 17p prop. That GT boat is more boat to push than you would think!
Sat Jan 26, 2013 8:56 am
4 stroke. That's why. throw a 70 yammy 4 stroke and it'll run. I'm a merc 2 stroke man but yammy four stroke
Sat Jan 26, 2013 9:11 am
Ill change the prop and pitch first and see what I can get from it.
Sat Jan 26, 2013 9:20 am
Sat Jan 26, 2013 9:22 am
Believe me I'm really surprised reguardless of 4 or 2 stroke
Sat Jan 26, 2013 9:29 am
should have got a 115 pro xs optimax
I gave up mud motors
Ran a 10.6 with less pitch today and nothing changed! The motor feels like it wants more at times. You can almost feel it take off for a sec but fall back off. Same speeds around 26-27mph. Something gotta be wrong with the motor. A guy in 25hp tiller passed me up in the canal!! Lol. Fuck my life!
Sat Jan 26, 2013 4:39 pm
My fishing boat is a 17' deep V Lund with a 50 HP Merc 4-stroke tiller. It came with a 13 pitch prop and I went down to 12 (4 blade stainless) for better hole shot went loaded with three guys. BUT, that boat is 1,000 lbs dry, has a 27 gal fuel tank, 3 batteries, two large live wells, two trolling motors. Top speed is about 29mph (can hit 30 at times). I lost just a little on top speed going down to a 12 from a 13.
With your rig (should be much lighter), and the fact that you have a flat bottom that get's on plane faster, I would think you'd want at least a 13 pitch or higher.
With your 10.6 prop, are you instantley on plane?? Does the motor seem to rev high? Sounds like it's pitched way too low to me...
Sat Jan 26, 2013 5:15 pm
I think you can get a little more out of this motor by removing a small air restrictor at the intake. I believe I remember seeing a post about this on another site about 2 or 3 years ago. Something about the ecu automatically sensing the increased airflow and recalibrating to a higher hp level--maybe 60ish hp. Might want to check into this before going about it blindly.
Sat Jan 26, 2013 5:22 pm
Talked to Hoyt today he said ez'ly I should be pushing 40. Im goig to raise the motor to the highest setting and run both props and see
Sat Jan 26, 2013 6:12 pm
Sat Jan 26, 2013 6:13 pm
Sat Jan 26, 2013 6:45 pm
Sun Jan 27, 2013 10:41 am
Baggy's Propeller Repair
(985) 868-0103
Baggy will tell you what's up.
Sun Jan 27, 2013 11:33 am
Tried again today after we raised the motor to the highest setting and ran both props again. Still 25-28. FML. Calling baggy and bringing the motor back where I bought it.
Sun Jan 27, 2013 12:55 pm
do you have a 20" shaft ob and a 20" transom??
Gator Trax Hybrid 1654 HuntDeck
Sun Jan 27, 2013 1:03 pm
21" tran. 20" shaft
Sun Jan 27, 2013 1:15 pm
Sun Jan 27, 2013 1:16 pm
x2 that man knows props and will get it right if the prop is the problem!
2013 1846 Gator Series w/ 35 GTR Hoyt's heads and gutted stock exhaust
Sun Jan 27, 2013 4:05 pm
baggy knows his props
i went from a 4 blade powertech 15pt to a 3 blade turbo 17pt... like a totally different boat
Sun Jan 27, 2013 4:21 pm
Tue Jan 29, 2013 7:37 am
MMT Moderator
What RPM are you running at your top speed TDUET?
GTB 1860 w/ 2019 GTR40XD-HO
Tue Jan 29, 2013 7:59 am
Easy quick fix! 3 cyl is blown in the motor. Going get my $$ back and going get a new one! Lol
Tue Jan 29, 2013 1:43 pm
That would do it, lol.
Tue Jan 29, 2013 1:58 pm
Tue Jan 29, 2013 6:18 pm
Users browsing this forum: No registered users and 101 guests
