dwhipper61
 Whats it worth
Looking to possibly purchase the following motor. Trying to get an idea of a fair price. Any input would be appreciated:
2004 Mud Buddy 4000, 160is hours, Power tilt/trim, Mikuni Carb, BPS Stainless Crossover exhaust and 2009 32" outdrive, short transom
Whats it worth and what kind of speeds can I expect on a heavy 1854 jon boat?
THANKS
Tue Mar 12, 2013 7:27 am |
barnes_53
 Re: Whats it worth
based on what you describe above I wouldn't pay over $1700 for it. Any pics?
Tue Mar 12, 2013 7:30 am |
odass
 Re: Whats it worth
have to be careful with the older balance drives. even tho it's a short transom motor, which the only difference is drove length, the 32" outdrive can still be to short on a short transom boat. I had problems with this on my first gator trax, the short transom for a 04 should have been 36 ". the 32 will probably work on a 15" transom height, but much taller will be a prob. good luck
_________________ Dead Fowl Custom 1954hd with a GTR
Wed Mar 13, 2013 3:13 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
 Re: Whats it worth
I've seen guys put the 40" outdrive on older hypers. You also need to consider how much it's goona cost to convert to new gears & belt tho. I'd shy away from it honestly.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Wed Mar 13, 2013 9:30 pm |
Okie Ghost
Joined: Sat Mar 14, 2009 9:57 pm Posts: 84 Location: OK
 Re: Whats it worth
That old of a motor probably has the old trim rocker on the tiller handle and not the newer "football" style. Miserable to drive, but you can "upgrade" for around 300$.
_________________ 1848 Brother Breaux 35 GTR Setx Heads, Mikuni, MM, Coils
NASHVILLE SUCKS
Thu Mar 14, 2013 12:06 am |
dwhipper61
 Re: Whats it worth
Thu Mar 14, 2013 2:41 pm |
Team Camo
 Re: Whats it worth
The old hypers used the same belt drive, but different outdrives to go from short to tall. They used a 36" on a short, & a 48" on a tall. Nobody does that today
Thu Mar 14, 2013 3:20 pm |
dwhipper61
 Re: Whats it worth
Thanks for the insight. In my search for a surface drive to replace my longtail, what should I be looking for?
Fri Mar 15, 2013 10:03 am |
odass
 Re: Whats it worth
id buy any brand that was newer , low hours under 300 or so. Well how much you want to spend might be a better question lol
Fri Mar 15, 2013 2:19 pm |
