It is currently Sun Jul 20, 2025 12:06 pm
Reply to topic  [ 53 posts ]  Go to page 1, 2  Next
 power trim on GD 35 SD
Post power trim on GD 35 SD
Anyone ever tried to put electric trim on a GD SD
Gen III Pro Drive with a JBP stage 2 pushin 18x54 madmancustom
Jus nut up and grab a handful of throttle
Wed May 15, 2013 7:10 am
Post Re: power trim on GD 35 SD
Not that I've seen.
Wed May 15, 2013 7:25 am
Eat - Sleep - Hunt ! ! !
Wed May 15, 2013 7:30 am
Like giga said "If you polish a turd it's still a turd!"
Wed May 15, 2013 7:33 am
Wed May 15, 2013 7:50 am
It don't work. Get it in heavy vegetation and it kicks your motor out the water. A trim would help it dig without kicking it out the water
17x48 extreme stage 2 GTR
Wed May 15, 2013 8:01 am
Wed May 15, 2013 8:08 am
I am thinkin bout welding on a bracket and replacing existing manual trim knob with a 12v linear actuator that way it'll still be balanced and still Kick up when needed . . . Would like to be able to make quick trim adjustments on the fly. Kinda hard to reach the trim bcuz of my hunt deck on back
Wed May 15, 2013 8:26 am
Seems like we would need neutral if we went with power trim on GDSD's...
Wed May 15, 2013 9:10 am
Wed May 15, 2013 9:11 am
Wed May 15, 2013 9:41 am
Wed May 15, 2013 4:43 pm
Wed May 15, 2013 4:45 pm
What u know I have a gd hull with hunt deck....
Wed May 15, 2013 4:56 pm
Wed May 15, 2013 6:05 pm
Wed May 15, 2013 6:09 pm
So put the prop half way in the water and air it out. Your a fucking moron. How bout you keep what you know nothing about to yourself cause your help won't get this guy anywhere.
Wed May 15, 2013 6:12 pm
Team marsh mafia. The problem you have is the same problem all balanced motors have. When the shit gets thick you have to try to put the prop into the water. Trim will keep it their and chew it up. If the prop can't bite then theirs no forward motion to move the boat. I say you try it can't hurt anything.
Wed May 15, 2013 6:17 pm
Wed May 15, 2013 6:21 pm
GDSD - 101
The GDSD SD prop is meant to "surface" - IE only the bottom half of the
prop engages the water when on plane and at speed....
If you submerge the prop too much - you loose speed....
If you "air out" or lift the prop too much - you loose speed...
The trick is to find the "sweet spot" where speed is maxed and best
performance is reached.... In veggies it is best to maintain speed
and occasionally -"air out" - or lift the prop for just a split second
from time to time to run "clean" and prevent veggies from wrapping
up on your prop.... When you plan to stop in veggies - totally lift
the outdrive all the way up and let the hull settle and stop.... When
you take back off - go deep for only a second or two then bring the
prop back up to its elevated surfacing position - and resume speed
on plane as before....
DDM - wants you to do the opposite - cause it leads to a bunch of veggies
wrapping up on the 3 blade and its blades can not push when it is wrapped
up like a ball.... The trim deep in vegies tactics that work on a PD or GTR
simply do not work on a GDSD....
Wed May 15, 2013 6:30 pm
Dumbass I'm sure his problem he's having is at slow speeds. That's why he wants to have a trim.
Gd 101
Pieces of shit don't run heavy vegetation
http://youtu.be/Y_Nk8nrRi5w
Wed May 15, 2013 6:35 pm
GDSD (or any balance motor) + heavy vegetation= sore arms next day end of story.
Wed May 15, 2013 6:37 pm
Your doing it wrong !
Let the man tell us about HIS RIG and WHAT HE WANTS....
Wed May 15, 2013 6:40 pm
DDM he talking about running Lilly's in deep water. Once u pick motor out with mud/lilly u stop moving and can't "air out"
Wed May 15, 2013 6:44 pm
I tell you what giga ill pay for you to come to south la. And put on a clinic for all the unfortunate gd operators who know nothing about running heavy vegetation!! Ill video it for all to see.
Wed May 15, 2013 6:47 pm
Wed May 15, 2013 6:49 pm
Him and aka could show us, bc he swears they can run anything to.
Ive run Lt gd for longer than I've run gatortails. Theirs no difference from gunning their sd than their Lt when it come to grinding trough thick shit.
Wed May 15, 2013 6:53 pm
Wed May 15, 2013 6:55 pm
Wed May 15, 2013 6:57 pm
This dude never said a thing about lillies. His question is simply about a trim.
The way you're talking about doing it sounds like a good idea that would work. I'm guessing the linear actuator would just push against the steel bracket that the trim screw pushes against now to continue to allow it to free float. Post pics on any progress, please.
Wed May 15, 2013 7:03 pm
Yea cootslayer thats what I was plannin on doin . . . I will definitely post pics when I do it
Thu May 16, 2013 7:04 am
I don have a prob in veggies. I jus do like giga says and lift prop out of water and clear out the crap and drop her down an go back to eatin. The prob I have is I do alot of changing from Deep to shallow and shallow to deep water. I lose 6 or 7 mph in deep water unless I adjust my trim
Thu May 16, 2013 7:10 am
OK - thats what I thought...
Your just running a bit too deep...
A quick tab bend will get you "dialed in" and you won't
need to run on the stop at all....
Bend the trailing edges of the 2 bottom horizontal fins - down 1/8"
at a time and test after each bend at different speeds....
Use a big azz cresent to adjust....
When it's "dialed in" - it should make you smile and drive better overall...
Thu May 16, 2013 7:16 am
If you bought it used - most guys bend those tabs UP cause
it adds a bit of life to a worn out prop....
If they are bent up - bent them straight first - then adjust from there....
A little bend makes a big difference in the "hydro-dynamics" of the
fin design - it needs to "self-adjust" to work at max potential....
Good Luck - and feel free to PM me for more help - I'm east of Houston
if you are ever over here lets cut a trail in WallysVille....
Thu May 16, 2013 7:25 am
I bought it new and Im actually gettin real close to needin a new prop . . .I am probly gonna get a new prop first then readjust my tabs . . . thanks for the info
Thu May 16, 2013 7:36 am
Giga = GD Dr.
:lol: :lol:
16X48 WELDBILT -25GTR EFI-sold
18x48 GTB - 35 GTR
Crown royal pro-staff
Thu May 16, 2013 1:02 pm
Thu May 16, 2013 1:46 pm
I'm glad I sold that pos
Thu May 16, 2013 3:55 pm
Thu May 16, 2013 4:02 pm
Users browsing this forum: No registered users and 181 guests
