It is currently Sat Jul 19, 2025 6:39 am
Reply to topic  [ 15 posts ]
 Aluminum gas tank dimensions
Post Aluminum gas tank dimensions
I just got a custom boat built and I decided after the fact that I want to put a big tank. Cause I'm tired of having to switch between 2 6 gal tanks i want one 12. But the plastic 12 gal won't fit under my deck I only got 11 inches of clerance what I'm getting at is I found a formula online you type in length x width x height and it gives you how manny gallons. So to check it I put in measurements for a 12 gal plastic tank and it says the plastic should hold like 20 gal I gota be missing something
2010 gtr cdi with a stage 2 pushing a 18x46 home made HEAVY DUTY boat
Thu Jul 25, 2013 6:13 am
Post Re: Aluminum gas tank dimensions
1 gallon is .1336 cu ft
17*38 Klibert 23GDLT
Thu Jul 25, 2013 6:19 am
Is your tank a perfect rectangular solid?
Thu Jul 25, 2013 6:40 am
What tank. I don't get it built yet
Thu Jul 25, 2013 6:51 am
They have an online calculator for this, u put n the l,w,h and it tells u how many gallons it will hold
Thu Jul 25, 2013 7:34 am
I barely read op lol
Thu Jul 25, 2013 7:39 am
Thu Jul 25, 2013 7:57 am
I figured that's what. It was for. But a aluminum tank don't need air space and all that to ?
Thu Jul 25, 2013 8:11 am
Length x width x height=??
divide that by 231 that will give u the gallons it's close i figured mine to be 16 gallons at the pump it was 15.7 gallons to the top.
Thu Jul 25, 2013 8:38 am
I've never seen an aluminum tank with air space I don't build them with air space either.
Thu Jul 25, 2013 8:41 am
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Thu Jul 25, 2013 8:49 am
I painted mine and left a little window around mine so I could see the fuel level. I would not advise using it as a seat, they do flex a good bit.
Thu Jul 25, 2013 10:03 am
Thanks fellas. and you answered my next question about durability. Probably not a good route for me.
Good idea about leaving a window if you paint it though!
27 PD FPR 16x36 skiff
Thu Jul 25, 2013 10:09 am
Thu Jul 25, 2013 5:18 pm
Go plastic!!
Thu Jul 25, 2013 5:33 pm
Users browsing this forum: Google [Bot] and 81 guests
