It is currently Tue Jul 08, 2025 1:54 pm
Reply to topic  [ 15 posts ]
 HOPKINS prop
Post HOPKINS prop
I just bought a Hopkins prop and a pro dive prop. I just wanted to see which one ran better for me .
Had have a f86 excel 18/54 with a pro36 with mods . It had 11 gal of fuel two people 260/175 and a duck blind on it.
I ran the pro prop first it ran ok had a vibration about 0-2000 rpm {never had a problem with there prop before} it ran 28-30 deep water.
I ran the Hopkins prop same day it had more low end and ran 30-32 in deep water .Just wanted to post some number. Has anyone had a problem with there pro prop ??
Sat Oct 26, 2013 7:22 pm
Post Re: HOPKINS prop
Which Hopkins did you get? How well did your bushing for in the hub of the Hopkins? Be careful. It needs to fit like the bushing does in the PD stock prop. If there is any play in it all, I mean ANY...you need to send that Hopkins to PD and let them turn it down in their lathe.
Sent using Morse Code from my not so smart phone.
Sat Oct 26, 2013 7:59 pm
The bushing went in good just like the pro drive prop I took it back off after I put the Hopkins on and it was tight look just like the old prop bushing .
Sun Oct 27, 2013 5:53 am
Interesting... what are the specs on your Hopkins prop? Pitch? Heavy cup or standard?
32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
Tue Oct 29, 2013 12:37 pm
Where do you buy them from
Tue Oct 29, 2013 12:51 pm
1848 ProDrive X Series w/ 36 PD
Tue Oct 29, 2013 12:56 pm
Tue Oct 29, 2013 1:12 pm
Thanks
Tue Oct 29, 2013 1:20 pm
Post HOPKINS prop
Hopkins propellor in Covington, LA. I have the Hopkins Cleaver in a 12 x 12. Not totally pleased with it yet. I need to bring it back to him for a little tweaking. Just don't have the time right now.
The Cleaver gave me a really great hole shot compared to the Prodrive stock tulip prop. But, load carrying is nowhere near what the tulip had...yet.
I don't know what it will do in the mud, yet. I have only ran the cleaver twice. Once with just me, once with two other guys. But, even just me in the boat- boat, motor, fuel, batteries and trolling motor is nearly 1600 lbs. total weight.
This is the cleaver.
Like I said, if you get one for a Prodrive, there have been a lot of guys that ran into problems running this prop because Hopkins doesn't turn down the bushing "just so." Prop goes on just a little cocked and things go wrong from there. I knew what everybody was talking about as soon as I tried to drop the bushing into the hub.
Tue Oct 29, 2013 1:21 pm
I really don't no what cup or pitch. I talk to him and told him what I needed and what I am looking for and he sent me a prop . It ran good the hole shot was good and the speed was up a little . Have not loaded it down so when I do I will let yall know how it does.
Tue Oct 29, 2013 3:02 pm
Any luck with the Hopkins on a GTR?
Seems like most run the GT stock prop, I figure there's a reason but gotta ask.
Tue Oct 29, 2013 5:35 pm
Running the Hopkins tulip 12x12 on my GTR and am very pleased with it.
Sent from my iPhone using
Tue Oct 29, 2013 5:56 pm
17x48 extreme stage 2 GTR
Tue Oct 29, 2013 6:33 pm
I had my friend do some work to it because it was slow on top. I can turn it 4700 if I need to but it's not pulling because it's trimmed so high.
Tue Oct 29, 2013 7:05 pm
Post HOPKINS prop
Was running 27-28 with it before I added cam now it's solid 30.
Tue Oct 29, 2013 7:06 pm
Users browsing this forum: No registered users and 56 guests
