It is currently Mon Jun 30, 2025 1:20 am
[ 8 posts ] |
Delta1389
Joined: Mon Jun 03, 2013 8:24 pm Posts: 310 Location: Morgan City, LA
 GD prop
Kinda confused here. Put a new backh20 prop (9x6) on my GD lt before September teal. ran great with it. Just changed it out Thursday. Had worn it down to 7.5". Put a new GD prop on and it's like the motor can't spin it. Really gives the motor trouble at high rpms in the water. Noticed a lot more cup in the GD prop over the backh2o. Wondering if yall notice a negative difference in performance when you put on a new GD prop.
_________________ 35 GTR on an 1844 Sportsman Fab hull Build thread: viewtopic.php?f=6&t=57498
Sat Dec 21, 2013 5:06 pm |
Delta1389
 Re: GD prop
Old prop vs new prop
Sat Dec 21, 2013 5:33 pm |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
 Re: GD prop
That prop looks to be 2 or 3 inches larger than the old one....you sure you got the correct new prop?
Sat Dec 21, 2013 5:58 pm |
Delta1389
 Re: GD prop
It had 9x6 stamped on the hub. Measured it and it 9" across. Only thing that could be wrong is it could be a 9x7 they mis stamped as a 9x6?
Sat Dec 21, 2013 7:39 pm |
OlSchool
Joined: Sun Jan 06, 2013 4:24 pm Posts: 384 Location: Louisiana
 Re: GD prop
No, it is 9x6. Just has a lot of cup when it's new. What size motor?
Sat Dec 21, 2013 8:20 pm |
Delta1389
 Re: GD prop
25 kohler
Sat Dec 21, 2013 8:55 pm |
OlSchool
 Re: GD prop
You should be able to turn that prop. I had a similar experience with a 23. I have a GD prop that is still 9" diameter with a slight wear on cup and I can turn it 3910. I put a new GD 9x6 on thinking it would maybe take 100 rpm but it dropped to 3600 or so at about the same speed. I put my old prop back on because it carries a load better. You don't have that option because your old prop is too far gone. What rpm can you turn the new prop?
Sat Dec 21, 2013 9:09 pm |
Delta1389
 Re: GD prop
No tach on the motor. Haven't put one on it yet. I can tell it's not what it was before though. Really need to get around to installing a tach on the motor.
Sat Dec 21, 2013 9:27 pm |
[ 8 posts ] |
Users browsing this forum: No registered users and 40 guests |
