It is currently Thu Jul 17, 2025 8:44 am
gfowel
Joined: Thu Mar 01, 2012 4:52 pm Posts: 1024 Location: Florida
 Re: Gator gliding my boat
Don't know not much of a fan of red. Might make it hard to hide. You might have to do more coats of the glide to hide it.
Mon Mar 17, 2014 7:42 pm |
krazo
Joined: Thu Sep 06, 2012 8:44 pm Posts: 667 Location: SE Bama
Ok that is what I was thinking. I'm going with the same thing you did.
_________________ 1754 prodigy- stage 2 GTR
Mon Mar 17, 2014 7:46 pm |
gfowel
Good deal, and when everyone said frog was good to work with they were right. He will answer your call and take the time to go out his way to help you.
Mon Mar 17, 2014 7:52 pm |
MudBuddy77
Joined: Mon Oct 03, 2011 5:56 pm Posts: 298 Location: Caddo lake
How long are you guys waiting in between coats? Should it fully cure each time, in between coats, for better results? Thought I saw dry to the touch in two hours. So would it bond better if waiting 2 hrs each coat? (For the base and g2 both)
Mon Mar 17, 2014 8:46 pm |
huck Finn
Joined: Thu Jan 31, 2013 5:42 pm Posts: 1913 Location: Conroe tx
Depends , on temps. , humidity , but definitely not. 2 hours , mine was dry to the touch within 15 mins or so , I started port side bow to stern , then starboard stern to bow , by the time I got to starboard bow the port side was dry to touch. , I essentially just made laps till I had 5 thin , thin coats on. . I let it cure / dry for about. 2 hours ( when I couldn't dent it with a fingernail ) before setting back down on trailer. , let it sit several days dry to completely cure before running in water. .
H Finn
_________________ Ole black water keep on rolling
18x54 Uncle J -GTR - with the koolaid Back H2o SWOMP 23 SS stage 2 15x36 GD Duck Skiff GATOR GATOR GLIDE PROSTAFF BACKWATER PROSTAFF http://www.gatorglide.com
Coupe rest in peace brother
Mon Mar 17, 2014 8:54 pm |
gfowel
Mon Mar 17, 2014 9:10 pm |
MudBuddy77
Just got my order in! Thanks for the info!
Tue Mar 18, 2014 7:04 pm |
gfowel
Tue Mar 18, 2014 7:10 pm |
lil Cajun
So after u apply the base and it cures do u need to sand again before applying G2-G4..?
_________________ 18/60 Prodive With Dual 37 EFI Prodrives Gen III...
Tue Mar 18, 2014 7:58 pm |
gfowel
Yes with either a scotch-brite pad or 400 grit.
Tue Mar 18, 2014 8:06 pm |
Users browsing this forum: No registered users and 84 guests |
