It is currently Mon Jul 14, 2025 12:57 am
Reply to topic  [ 14 posts ]
 What paint rollers to use?
Post What paint rollers to use?
I'm about to paint my alweld with Duralux aluminum boat green. I understand the prep and process of doing this. Everyone says to roll it because the product won't spray. What kind of and size rollers do I need? I brush the nick and crannies and strakes? Thanks
Wed Apr 09, 2014 11:08 am
Post Re: What paint rollers to use?
a 6" inch X 3/8" to 1/2" nap roller the white ones with the yellow stripe running through it, get at Home depot
Wed Apr 09, 2014 3:17 pm
Spray it with a wash down gun then have someone roll it while it's still wet. Painted many hard to get spots on drilling rigs that way.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Wed Apr 09, 2014 4:04 pm
Listed as siphon spray blow gun
Wed Apr 09, 2014 4:08 pm
I used wooster 4" roller 3/16" nap because it leaves a smoother finish
Wed Apr 09, 2014 8:44 pm
So u can't thin that paint down and spray it? I was thinking about doing mine but was going to spray it. Btw how much ain't do you use for a 1642 flat?
25 yamaha pushing a 1642 welded flat
20 hp go-devil longtail for hunting
Wed Apr 09, 2014 9:40 pm
Wed Apr 09, 2014 9:44 pm
I've seen it sprayed a bunch of times
Sent from my iPhone using
Wed Apr 09, 2014 9:58 pm
Try not to thin it much. The finish won't be as durable if you use too much thinner
Wed Apr 09, 2014 10:04 pm
Oh, I thought you couldn't thin it from this post...how far does the paint go? 1/2 gallon or what for a 16 foot boat?
Wed Apr 09, 2014 10:16 pm
I don't know about Duralux, but I used Pettit Shipendeck to paint my boat. Sprayed 3 coats on the inside and the outside. Used 3 quarts. However, I did not paint the floors or the front deck.
Like dfou said, the Duralux will not be as durable if thinned. The Pettit sprayed pretty easy without thinning. Plus you get a better finish by spraying IMO.
1648 GDSD 27 GDSD
Thu Apr 10, 2014 12:15 am
Any roller will work 1/4" nap will give ya a smoother finish thou.
Thu Apr 10, 2014 5:42 am
its a mud boat who cares. put sand in it while its wet, paint over it again
Thu Apr 10, 2014 6:35 am
Buy a hvlp gun with a 2.5mm tip. U won't have to thin it much. About 50 bucks on the web
1648 gd hull flying in front of a stage 3 with fpr
Fri Apr 11, 2014 4:41 am
Users browsing this forum: No registered users and 62 guests
