AKA Freshwaterkilla
 Re: So How Good is EFI
Mon Apr 21, 2014 4:04 pm |
cb5331
 So How Good is EFI
Mon Apr 21, 2014 4:39 pm |
dfou
Joined: Sun Dec 12, 2010 12:38 am Posts: 3986 Location: Pville, La
Mon Apr 21, 2014 4:47 pm |
cb5331
That explains a lot of things.
Mon Apr 21, 2014 4:50 pm |
THE TANK
Joined: Wed Mar 04, 2009 7:34 pm Posts: 1080 Location: Coteau Homles, La
STT ask if someone can clean his carb!
Sent from da woods!
Mon Apr 21, 2014 6:32 pm |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
Mon Apr 21, 2014 6:43 pm |
stopthetalk
Mon Apr 21, 2014 6:44 pm |
THE TANK
I had carb trouble twice in 2 weeks so I'm done EFI here I come!
Sent from da woods!
Mon Apr 21, 2014 6:53 pm |
fowllife08
Joined: Sun Sep 18, 2011 7:25 pm Posts: 3676 Location: down in da flats, LA
_________________ 35 GTR chasin a BBC 1848
Mon Apr 21, 2014 7:45 pm |
THE TANK
Mon Apr 21, 2014 7:55 pm |
cupped up
Joined: Tue Jun 05, 2012 7:25 pm Posts: 4205 Location: St. Amant, LA
Why not put the EFI on the stage 2?
Mon Apr 21, 2014 8:07 pm |
THE TANK
Mon Apr 21, 2014 8:38 pm |
banded-mallard
Tue Apr 22, 2014 4:27 am |
muddawgchuck
Joined: Fri Oct 01, 2010 9:22 pm Posts: 959 Location: Spurger Tx.
_________________ 18x54 WC custom 36PD EFI
Tue Apr 22, 2014 7:23 am |
Will
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Tue Apr 22, 2014 7:42 am |
baron von
Joined: Tue Jan 21, 2014 2:52 pm Posts: 2806 Location: Minnesota
looks pretty basic - according to PD it will function like your vehicles ECU, compensating for different engine scenarios - good or bad
_________________ that's going itch when it dries
Tue Apr 22, 2014 8:07 am |
banded-mallard
Who is the manufacture of the kit, is it straight from briggs or a side company like ecotron like the one Stu used?
Tue Apr 22, 2014 9:20 am |
baron von
you mean who is compiling the kits? - components manufactured by Delphi, Bosch, and Kehin, I just cant wait to get off the waiting for motor list to waiting for EFI kit list
Tue Apr 22, 2014 9:28 am |
Puddler45
Joined: Thu May 03, 2012 9:07 am Posts: 1199 Location: Wisconsin's waters and woods
_________________ 1744 floating a 23 MBHD Stage 2
Tue Apr 22, 2014 10:13 am |
Puddler45
maybe STT can answer this one...What is the ideal A/F ratio for a briggs 35
Tue Apr 22, 2014 10:20 am |
cb5331
 So How Good is EFI
Yes, but like you said, it will not adjust itself to accomodate for load and weather changes. I try to tune them a little fat with a load on a hot day and leave it like that year round. Then it wont be way too lean on a cold day with a heavy hunt load. You could optimize it for season changes if you wanted but our weather swings down here are way too fucked up. If you tried to keep it perfect all the time, you'd be changing shit multiple times a day during duck season.
Tue Apr 22, 2014 10:23 am |
cb5331
Biggest thing you're trying to do is make a smooth transition off the needle. It's very hard to feel it, but you can go from way fat to way lean in just a couple hundred rpm's on a carb that seems to run great. It's really hard to know this without a lil help.
Tue Apr 22, 2014 10:26 am |
cb5331
Tue Apr 22, 2014 10:29 am |
Puddler45
I would base this off of a premium fuel 91 to 93 octane. My assumption would be that the efi is programmed to maintain a A/F ratio within a certain range. So there must be a ratio at which more power is produced since STT claims he has dyno numbers.
Tue Apr 22, 2014 10:37 am |
cb5331
 So How Good is EFI
I use the lambda setting on my meter. Its like a standard for pump gas. I don't remember the real ratio off the top of my head
Tue Apr 22, 2014 10:46 am |
muddawgchuck
Tue Apr 22, 2014 10:52 am |
cb5331
 So How Good is EFI
14.7 is the afr the lambda setting is based off of. On my meter a reading of 1 would equal an afr of 14.7. Over 1 is lean, under is rich. I shoot for .85 on a hot day with a load.
Tue Apr 22, 2014 10:58 am |
cb5331
Tue Apr 22, 2014 11:13 am |
Puddler45
thanks for the info CB
So to be safe the actual A/F ratio should be less than 12.5 to keep the engine from knocking
Tue Apr 22, 2014 11:19 am |
cb5331
Most of the reading i've done goes off of the fuel not the engine. Would not mind doing some reading on different engine types though if you know of any helpful links.
Tue Apr 22, 2014 11:27 am |
cb5331
 So How Good is EFI
Tue Apr 22, 2014 11:32 am |
Jamie B.
Tue Apr 22, 2014 5:46 pm |
cb5331
 So How Good is EFI
You will too!  actually, i bothered gary several times before i read mine, thouroughly at least.
Tue Apr 22, 2014 5:51 pm |
Jamie B.
Tue Apr 22, 2014 5:55 pm |
msm8281
I only read instructions after I put something together and still have multiple peices left when im done:lol:
Tue Apr 22, 2014 6:22 pm |
Gameover
Joined: Tue Jan 03, 2012 9:06 am Posts: 3673 Location: Prarieville,LA
_________________ 1754 GTR Xtreme CC w/ Purple Kool-aid Additives
Tue Apr 22, 2014 6:34 pm |
Russ
Tue Apr 22, 2014 6:36 pm |
Jamie B.
msm8281
I think it's an art to put something together without all the pieces and it still work:grin:
Tue Apr 22, 2014 6:44 pm |
cb5331
This thread is really starting to shed some light on what caused the epidemic of blown up briggs and stratton lawnmower engines on mudmotors.
Tue Apr 22, 2014 6:46 pm |
