It is currently Sat Jun 28, 2025 8:45 pm
Reply to topic  [ 17 posts ]
 29hp mud buddy?
Post 29hp mud buddy?
Hi I'm new to MMT, been reading and learning a lot as I've never owned a mm but will be buying in the near future. I have a 14x42 Jon boat and just found a mud buddy 29 hp Kawasaki and was wondering if that is to big for my boat and if it's a good mm
Thu May 15, 2014 6:32 pm
Post Re: 29hp mud buddy?
Its a good mm. Itll work but its alot of motor for that boat. That will get you out of pretty much anything it gets you into. just be careful.
Fri May 16, 2014 6:10 am
My buddy has one on a 1554 Jon. Tac read 2,200 when he bought it. That was 8 years ago. He can go just about anywhere he wants.
Good motor for sure.
1648 GDSD 27 GDSD
Fri May 16, 2014 6:55 am
It will be ok, just beef up that transom and put some splash guards so you dont swamp
Fri May 16, 2014 9:58 am
Thanks for the replies, I mostly trap from my boat so I carry a lot of weight already with that considered am i pushing my luck quite a bit?
Fri May 16, 2014 11:56 am
I ran one on back of a 1440 I had. I had to build a box behind the front deck to house the battery and gas tank, becuase with either one of them in the rear the stern squatted too bad. Once I moved some weight to the front of the boat she ran like a champ.
Fri May 16, 2014 12:15 pm
Just distribute the heavy stuff to the front and middle so it sits even, and dont let of too fast
Fri May 16, 2014 3:24 pm
Thanks I think it might be a bit much for my boat, I'll just keep saving for a backwater 23hp
Sat May 17, 2014 12:00 pm
Whered u find that 29, and how much?
Sat May 17, 2014 12:08 pm
wwhat is the brand of the boat?
Sat May 17, 2014 1:23 pm
I found it on trapperman.com $2000 located on south central Iowa, it's 4 pages deep in the trap shed titled mudd motor, my boat is a alumacraft and I load it extremely heavy during season so I think I better just go with a smaller one, I talked to back water n will prolly go that route
Sat May 17, 2014 1:32 pm
why not try and find you a larger boat so you have more room?
Sat May 17, 2014 2:10 pm
Most of my loading and unloading is done in a inch or less of water with a bit of dragging, had a 16x48 but it was real tough to drag n load n unload, love my 14' just need a mm
Sat May 17, 2014 3:21 pm
Back Water is the way to go. I have a 23 Swomp on a 1448 and it's a sweet combo. Run your gas tank or battery up front and you will have a sweet setup.
Backwater Swomp 23 / Lowe L1448M
Mon May 19, 2014 9:45 pm
They got a 29 Kawi mb sd on local forums for 1700 right now if anyone's still lookin. If I recall correctly they are already fuel injected strong motors
17x54 custom CC with stage 3 GTR.
Mon May 19, 2014 10:13 pm
They are nice. And yes, the 29s have fi.
Mon May 19, 2014 10:51 pm
I had a 23 hp mudbuddy on a 14x42 jon boat and it was the perfect setup until I squared a stump up just right. Boat got a hole the size of your fist. Good thing I was close to the bank. Other than that I loved that combo.
Fri May 23, 2014 8:10 am
Users browsing this forum: Google [Bot] and 55 guests
