It is currently Sun Jun 29, 2025 2:00 am
Reply to topic  [ 6 posts ]
 Hard to drive
Post Hard to drive
So I have been looking on here for an answer and figured it be easier to just ask. I just bought my first longtail. It's a 24 hp beavertail on a 1648 short transom boat. I ran it yesterday and after 20 mins it's super tiring. The prop won't stay in the water and you have to keep pulling up on the handle to keep it in the water. I know the cav plate prolly needs adjusting but which way does what? Also how should the trim bolt be set? Thanks for all the help.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Sat May 24, 2014 1:33 am
Post Re: Hard to drive
Bend the cavitation plate up 1/8" at a time until it stays in the water.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Sat May 24, 2014 5:50 am
Sat May 24, 2014 2:01 pm
Even after you change your settings, its going to give you a work out while running it. With my long tail I normally didn't notice it until I got home since I was too busy running $h!t over.
-No Fly Zone- Pro-Drive CC
Sat May 24, 2014 2:40 pm
Thanks for the help. I will give that a try.
Sat May 24, 2014 2:52 pm
Let us know how it went. There are many variables to get a proper planing depth of the prop end of an LT. My friend has never had to touch his cavitation plate on his 1648 Lowe MV rivetted hull/ with a 25 HP GD LT. On all three of my previous GD LT's I had to bend the cavitation plate. My 2004 27 HP MB LT came with a "trim tab" on the trailing edge of the cavitation plate; this is held on by machine screws. I found this much easier to bend and achieve the same effect as on the GD's. You might consider fabbing this for the future to make it easier. I know the BackH2O line of LT's do not need this because the plate is curved to begin with and adjustments are different. Apart from the plate adjustment, which you do incrementally, like fireman said, how you distribute your weight in your boat hull will also affect planing depth and performance. A worn prop will also affect not only speed/push, but the planing depth as well. Although my 27 HP is rated for the 9x7 prop, I run better with a 9x6. Good mudding!
Sun May 25, 2014 7:39 am
Users browsing this forum: Majestic-12 [Bot] and 52 guests
