It is currently Thu Jul 03, 2025 8:04 pm
[ 30 posts ] |
FPR,,,, how reliable is it?
dennishaussler
Looking for info on reliability on FPR units. Anyone been running one for awhile and can offer some feedback? Thanks for any help.
Thu Mar 17, 2016 8:50 am |
jakehawk9
Joined: Wed Jul 01, 2015 6:06 pm Posts: 1447 Location: South central, ks
 Re: FPR,,,, how reliable is it?
Prodrive. Pretty reliable
Thu Mar 17, 2016 8:53 am |
wade_660
Never had a problem with mine. 200 hours
Thu Mar 17, 2016 11:07 am |
banded-mallard
None here either, and where I hunt you better have it. The only issue I ever had was the switch went out. I have replaced the switch and added solenoids to protect the switch. It also allows the trim and hydro pumps to receive full power from the battery. Before all the juice was ran through the switch. Works faster and smoother now with the addition of the solenoids.
Thu Mar 17, 2016 11:33 am |
dead animal
Thu Mar 17, 2016 12:40 pm |
Bdesroch
Joined: Thu Sep 18, 2014 11:21 am Posts: 12 Location: Marrero
IMO it is far more reliable than I could have ever expected. I bought a used 27, and it was not equipped with the reverse; so I purchased the kit from prodrive. And, I can honestly say it is damn close to the best $500 I have ever spent. Because having the FPR has with out a doubt got me out of some pretty STICKY situations, where if otherwise, my only other option was a pushpole I would be completely SOL.
_________________ 27 PD w/ 1448 Custom Alweld
Thu Mar 17, 2016 1:12 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
_________________ 1850 & 36pd
Thu Mar 17, 2016 1:43 pm |
flint87
Thu Mar 17, 2016 5:15 pm |
Swamper01
Joined: Tue Jan 14, 2014 7:57 pm Posts: 470 Location: Running between Manchac and the Basin
Just make sure this doesn't happen to you haha
_________________ 18x40 skiff/35 hp GTR
Thu Mar 17, 2016 7:21 pm |
Old School
Joined: Thu Dec 17, 2009 9:44 pm Posts: 3067 Location: Earth
Get you one of the Godevil R's
_________________ Gator tail
Thu Mar 17, 2016 7:27 pm |
BlueShamu
I'd go with VERY reliable lower unit. http://youtu.be/TO3ffRwJ8jE
Thu Mar 17, 2016 8:24 pm |
tchauvin
Joined: Wed Jul 13, 2011 6:23 pm Posts: 4898 Location: Bourg LA
I had about 1,000hrs no issues besides water intrusion. Fixed and no worries...
Lower unit is very over built.
Fri Mar 18, 2016 9:28 am |
Buddy
Joined: Mon Aug 06, 2012 9:06 am Posts: 579 Location: Tallahasse, FL
Very reliable. Its and overbuilt gear driven set up....Not a belt.
Only problems i have heard about have been caused by lack of maintenance.
_________________ 1754 XSeries Kawi Powered PRODRIVE ...
Fri Mar 18, 2016 9:51 am |
Ghostly
If one would google reliability... prodrive fpr should be the first thing that comes up... More reliable than birth control I can tell ya that! 276hrs shaft broke ...but fpr still pulling hard. Prodrive rebuilt lower unit installed greese inserts instead of oil..no wear at all on my gears 276hrs of flooded timber an cypress swamp longtail country. O I also pulled in 2d iffrently motors after search n rescue because of belts... 1 motor had less than 20hrs.. My 2 cents
_________________ Going to Disney World is like Going To the DMV, Instead of Walking out Once Finished Jumping Back In Line At the DMV…
Sat Mar 19, 2016 6:43 am |
Russ
FPS is intermittent, though.
Sat Mar 19, 2016 11:02 am |
Brokeknee
350 hours on my unit and no problems. I've hit stumps while idling so hard it shut the engine off, and still no problems.
Sat Mar 19, 2016 9:29 pm |
brycecheramie
Hitting stumps while idling is not a hard hit
Sun Mar 20, 2016 1:34 am |
SwampnutzWi
Joined: Sat Aug 23, 2014 7:55 pm Posts: 100 Location: Central Wi
Manual FPR reverse works like a ratchet. Aka the mechanisms are pretty dam bullet proof
Wed May 04, 2016 6:25 am |
Crews
Joined: Wed Jan 14, 2009 9:07 pm Posts: 2260 Location: Lafayette
FPR's reliability is absolutely above reproach. Shouldn't even be a question.
_________________ 24x60 Dual Prodrives
Wed May 04, 2016 9:22 am |
WhoDat88
Joined: Thu May 23, 2013 4:24 pm Posts: 2912 Location: Thibodaux, La
Not much to it. Works very well
_________________ 1850 Predator Series Stick Steer Option 40HP Gatortail
Wed May 04, 2016 3:19 pm |
MaXXis85
As mentioned above, I wouldn't worry much about the Pro-Drive. Worry about the boat you bolt it on.
Thu May 05, 2016 6:25 am |
Frog
_________________ http://www.gatorglide.com/
gatorheads@comcast.net
Thu May 05, 2016 6:49 am |
BlueShamu
Tue May 10, 2016 7:49 pm |
swamp_fox
Joined: Tue Oct 08, 2013 5:39 pm Posts: 265 Location: St.Amant, LA
Blue, I don't appreciate you hunting where I hunt! LOL
Sent from my SAMSUNG-SM-G890A using Tapatalk
_________________ 17'Extreme Metal Fab. Skiff - 23 GDLT
Tue May 17, 2016 2:54 pm |
BlueShamu
Who said I was hunting? [FLUSHED FACE]
Tue May 17, 2016 5:16 pm |
swamp_fox
There ain't nothing else to do there...haha
Wed May 18, 2016 9:48 am |
swamp_fox
By the way, that is a really awesome video, makes me think again about a surface drive. Do you run stuff like that every weekend (during hunting season)? If that's public, I do think I know where that's at. Sent from my SAMSUNG-SM-G890A using Tapatalk
Wed May 18, 2016 9:53 am |
BlueShamu
No...not like that every weekend. That is public ground....and there is a LOT of that stuff. My lease is actually in the wide open, bottomless marsh. But, I have run it through flooded timber in MS to bays and marshes of South LA. Gets me where I need to go....and more importantly; back.
Wed May 18, 2016 12:49 pm |
WhoDat88
Blue has several good videos on you tube
Thu May 19, 2016 8:28 pm |
swamp_fox
Ahh, ok I just went looked. I always like the video in the marsh showing the hydro reverse. Didn't know that was him.
Fri May 20, 2016 2:12 pm |
[ 30 posts ] |
Users browsing this forum: No registered users and 62 guests |
