It is currently Wed Dec 17, 2025 5:43 am
Reply to topic  [ 20 posts ]
 Hydro steering or Stick Steering
Post Hydro steering or Stick Steering
PD experts, I'm debating between the hydro steering and stick steering upgrade to my hull. Those with either, how do you like it?
40HP Gatortail
Mon Mar 21, 2016 5:49 pm
Post Re: Hydro steering or Stick Steering
Same here,
my next rig with be one of the 2.
Cant decide.
But im thinking CC just to have more room.
But, I will go with a stick steer if I can get the extra piece for the back deck that hopefully will fit ontop of the Stick steering components.
Mon Mar 21, 2016 5:59 pm
I run timber 90 percent of the time. This year the water was up so the modded 40 merc did everything I needed it to. But If I had to go to a remote steer surface drive it would be a stick steer. That being said, unless your running tight (and I mean TIGHT) trails, I'd go with a cc. Especially if it's your year-around boat.
Mon Mar 21, 2016 6:10 pm
Stick steer is nice for how rapid you can move side to side. But with any remote steer you loose considerable overall sterring.(can't turn as sharp either direction) stick steer has a higher profile, of which you will sit on top. Console has similar height to motor and you will have some protection being behind the console. It also takes up a considerable larger area in the boat floor. To me console was the way of go. I don't see many situations the stick steer would be ideal.
Mon Mar 21, 2016 6:42 pm
I'm considering the stick steer because I can sit up top and pop from duck blind hole to dick blind hole and fish bass with out ever getting out of the seat. However it does take up space. Hydro steering is very nice. My current duck spot is a 45 minute run which generally always has rough water and cross winds. That tiller will work you hard. On the stick steer I can pop the seat off easily to lower it to a decent level to get in the blind
40HP Gatortail
Mon Mar 21, 2016 7:08 pm
Why does the stick steering setup HAVE to be built so tall? I don't see anything that would require the seat height to be so far up. Might have to get creative with the steering linkage but I think a stick steer that sits down inside the hull would be the ticket. Ideally you could sit down the same height as the top of the motor.
If I ever were to do a console, it will be a real short side console. More like a bass boat type layout.
-Custom pool noodle
-stage 4 water wings
Mon Mar 21, 2016 9:26 pm
40HP Gatortail
Mon Mar 21, 2016 9:52 pm
Yep. Basically an aluminum flat bottomed bass type boat with plenty of deck space for fishing and a mud motor. I've had the idea brewing in my head for a while...
Basically, think of this http://www.rangeraluminum.com/model.cfm?sid=7324 Stuck in your favorite mud hull....
You'd obviously have to pay attention to weight and such but I think it could be done and would be damn nice to fish the backwater from.
-Custom pool noodle
Mon Mar 21, 2016 10:24 pm
40HP Gatortail
Tue Mar 22, 2016 5:01 am
Center console with a ****** knob. I'll never go back to a tiller.
Tue Mar 22, 2016 11:31 am
This is all you pal...
Tue Mar 22, 2016 1:04 pm
Another..
40HP Gatortail
Tue Mar 22, 2016 1:13 pm
No bud, it's a sportsman fab. I have a GTR CC...
If mostly fishing, you can't beat the side console, followed by the CC.
Tue Mar 22, 2016 5:42 pm
40HP Gatortail
Tue Mar 22, 2016 8:27 pm
Tue Mar 22, 2016 8:48 pm
Wed Mar 23, 2016 5:21 am
40HP Gatortail
Wed Mar 23, 2016 5:53 am
Hydro, they shouldnt even offer teleflex.
Wed Mar 23, 2016 8:36 am
Man 45 minutes runnin' when it's 25* will make you appreciate getting that CC to hide behind and the first time you smoke a stump followed by four logs crossed together you'll wonder why the HELL ya didn't do it sooner! Don't buy that BS about it being slow to turn either, getcha tractor knob if you've really gotta be cranking on it often.
PRODRIVE 1860 CC
"Let the good times roll"
Wed Mar 23, 2016 7:03 pm
