It is currently Thu Dec 18, 2025 11:38 am
Reply to topic  [ 12 posts ]
 37 efi gtr electric reverse tiller
Post 37 efi gtr electric reverse tiller
Who all has one and what do yall think of it so far???
Wed Apr 27, 2016 7:52 pm
Post Re: 37 efi gtr electric reverse tiller
Their awesome and proven.
18x48 extreme with 37 gtr
past boats
07 gtr on 16x54 alweld
Thu Apr 28, 2016 2:16 pm
Been having mine for 1.5 years and over 200hrs with no problems.
Fri Apr 29, 2016 9:56 am
So can someone please explain how the electric reverse works ? I'm thinking about buying a newer motor with EFI & reverse and know very little about how gator tail reverse works. Thanks
1856 Go devil / Gator Glided
HD 4000 MB Sport
Tue May 31, 2016 10:04 am
instead of a hydraulic brake caliper holding the planet carrier, the second electric clutch acts as a brake to hold the planet carrier.
Tue May 31, 2016 10:15 am
So it's a planetary transmission? How exactly does it work? I know GTR has a brake handle but how do you get the transmission into reverse? Does the clutch have to be in neutral before attempting to engage the transmission? Thanks again. There aren't any dealers up this way or I'd go look at one...
HD 4000 MB Sport
Tue May 31, 2016 10:32 am
On the hydralic YES, it had to be in neutral. If you squeezed tge lever it would kill the motor.
On the E reverse it is all in one switch. Instead of the old two position toggle(neutral/forward) the E reverse is a 3 position toggle. F-N-R. You cannot engage it in both.
As otvers have said its a similar design but instead of and atv caliber squezing a rotor bolted to a planetary. You have another cutch that engages to give reverse.
Tue May 31, 2016 11:29 am
Tue May 31, 2016 12:23 pm
Ok. Will get back to you
HD 4000 MB Sport
Wed Jun 01, 2016 11:16 am
Okay, So now they have TWO electric clutches on their engine?
And the second electric clutch locks up the planet carrier gears causing the output to be reversed?
That has to be a definite improvement over a mechanical brake...
Is everyone happy with it or are there concerns over how long the clutch will last before needing to be replaced?
Thanks for any input...
HD 4000 MB Sport
Wed Jun 01, 2016 12:28 pm
Yes, it reverses very hard with no slip.
Wed Jun 01, 2016 1:46 pm
Wed Jun 01, 2016 1:53 pm
