It is currently Wed May 14, 2025 9:56 am
Reply to topic  [ 56 posts ]  Go to page 1, 2  Next
 Speed!! MPH
Post Speed!! MPH
Provide following:
(1)boat make/size/flat or mv
(2)motor HP/ brand/ longtails only!
(3)prop size/# of blades
If your feeling frisky....(4) RPM's and load out
Fri Aug 26, 2016 6:19 pm
Post Speed!! MPH
1542 Alweld
25 MBLT
9x7 worn slightly
Turning 3750-3800 in water
Solo seeing 21-22
Loaded seeing 17-18
Sent using smoke signals
15/42 Alweld 25 MBLT
Fri Aug 26, 2016 6:30 pm
Post Speed!! MPH
Some douche already had a thread like this before he was banned...
1860 GDB
35 GDSD
Stock prop
Turning about 3900-4100
Solo 28
2 men 26
3 men a loaded 45 qt yeti two batteries and 12 gallons of fuel 25 mph bumping 26
Motor has cam, heads (.040), Mikuni and a gutted stock exhaust.
Carb is not tuned right, will update speeds after I borrow an a/f meter from Russ.
Fri Aug 26, 2016 6:59 pm
Post Re: Speed!! MPH
Shouldn't this just only be longtail speeds?
Fri Aug 26, 2016 7:10 pm
Fri Aug 26, 2016 7:18 pm
Post Speed!! MPH
I'll add something constructive though.
Had a 1844 godevil boat
25 godevil longtail
9x6 prop
No mods
18 unloaded
16 loaded real heavy.
Miss that boat. it would go anywhere and I could push it on dry sand bc it was light and had steel flex on bottom
Fri Aug 26, 2016 7:21 pm
Flint87, guess another douche is here! I don't discriminate, if you want to talk about your S(short)D(dick), go ahead. This is open to whoever wants to comment. I've looked for a thread comparable but struck out.
Fri Aug 26, 2016 7:52 pm
Just shows how lazy you are, theres a reviews section that has 100s of boats with clear info of what you are looking for.
Fri Aug 26, 2016 7:58 pm
If you want sd speeds, you should post in the cyber mudfest section, not the longtail. This is however the perfect spot for longtails. Be prepared for some lying, as apparently speed is something worth telling some fits about. Also, flint wasn't calling you a douche. He was referencing one that actually had attempted to collect and post information related to your thread topic, but he's now banned.
What the hell is with all the sensitivity turn butthurt lately because someone can't understand what was posted. Yet another that has been here less than a couple weeks going off because of some perceived slight.
Fri Aug 26, 2016 8:00 pm
Post Speed!! MPH
The great philosopher *russ* has spoken! I'm in law enforcement, you think I get butthurt? Bernie* Lazy, maybe, or possibly a little intoxicated on my night off after dealing with stupid ass people all week! My bad. You'd think I posted on the gymnastic page my niece follows. Your right I was comparing all and will move it too the main page. Your right I've been here less than a week, but I've ran a motor for a few years. Not an expert but not a green horn either.
Fri Aug 26, 2016 8:19 pm
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Fri Aug 26, 2016 8:30 pm
Fri Aug 26, 2016 8:37 pm
love this forum! The cool and the sometimes not so cool. Thank you gentlemen.
Mark F. Cheney
on the Great Salt Lake marsh
Fri Aug 26, 2016 9:02 pm
Post Speed!! MPH
I love it too....now that I know the rules. Everyone keep answering unless it's something other than a longtail!
Fri Aug 26, 2016 9:16 pm
18/48 Alumitec
35 Backwater LS
9/8 prop
37-3800 RPM's
19 empty 17 with a hunt load and 3 people
Sat Aug 27, 2016 6:11 am
Everybody here stretches their "longshaft" a bit. :mrgreen:
2004 1648 tracker grizzly mostly flat
2016 26.5 EFI Backwater SS 59"
9x7 prop
stock
tops out at 3850 rpm 20.4 mph just me (205) and gear
Would love a custom 1844/1848 true flat hull.
Best thing I did this year was buy the BW and put slick pads on the trailer bunks!
Sat Aug 27, 2016 6:13 am
Interesting. Never been called a philosopher, not even sarcastically. Thanks for that.
1652 (heavy for size)
MudBuddy w/24 hp honda
9x6
No clue on rpms
18 solo, 17 with 2 and all the hunt stuff. 15 with 3 and hunt load, close to not planing.
9x7
19 solo, would barely plane 3, so probably 14. Shallow water, both props did fine with 3 and picked up a little speed.
Sat Aug 27, 2016 6:35 am
1548 Weldbilt semi V (4*)
72" MB Longtail 20hp Honda with mild mods
Heavily cupped 9x4 prop
4500ish solo, 3900-4000 w/hunt load and two men
20mph when the stars aligned, 16-17 with load. (2 men, several doz decoys, guns, etc)
-Custom pool noodle
-stage 4 water wings
Sat Aug 27, 2016 9:29 am
1854 prodigy flat bottom
37hdr
12x10 big blade worn to hell
RPMs are high due to worn prop
I've had her up to about 78 mph on the interstate but I know she had more left in her!
Sat Aug 27, 2016 9:32 am
1971 Johnson corp 14x44 flat bottom
1989 15hp go-devil
9x3 go-devil prop
Bumped timing, stock (vangaurd) 23hp camshaft slightly gutted muffler
6 gallon tank, small battery, lawn chairs, fishing gear, 5 gallon bait bucket me (185) my son (60's)
2anchors.
Avg mid teens in the small rivers we fish.
3200-3400 cav plate under water
3600-3700 on the surface of the water.
14x44 riveted flat bottom jon pushed by old skool hopped up 15Hp GDLT.
Mon Aug 29, 2016 11:14 am
Post Speed!! MPH
2003 GD 18/44
2005 MBLT 72" 29 vanguard
Before foam removal
BPS 9x6
3600-3700 rpm
15 mph
Average hunting load
Fri Sep 02, 2016 11:05 pm
Post Speed!! MPH
Took the 18x44 out yesterday.... After foam removal.... Peak speed was 18.7mph..... Avg speed was 17.6mph...... Fighting current, held a solid 17.2..... Turns 3600-3650
Tue Sep 06, 2016 11:13 am
I'm running a 16x48 alweld flat bottom boat with a stock 22hp 670cc Predator motor on a mayhem mud motors longtail frame and cruise solo with a dog at 18mph and knocking on 20mph when I get on it.
I will be curious to see what it does with a hunt load
Go devil duck skiff 15' x 36" 2005 model
Backwater swomp ss frame , 23 built stage 2 block 13' model
Speeds 26-27 mph with 9x8 backwater prop
Speeds 24-26 with 10x5 backwater prop
9x8 is my ride prop, 10x5 is my hunt prop.
And yes folks on here have seen and will verify these speeds. She fast, for a longtail.
Huck
BACKWATER PROSTAFF
Tue Sep 06, 2016 12:31 pm
I know that is legit, Huck, you are the paradigm! I just entered the 20 mph club, lost my hat to prove that, sure is fun!
Tue Sep 06, 2016 2:09 pm
16/56 weld built
Twin 18hp gd lt
No clue on rpms
18 no matter me or 4 an hunt gear
16ft by 56 custom weldbuilt with twin 18hp godevil longtails
Mon Sep 19, 2016 8:55 pm
:arrow: :arrow: :arrow:
http://www.gatorglide.com/
gatorheads@comcast.net
Tue Sep 20, 2016 4:34 am
Another one
Tue Sep 20, 2016 5:26 pm
1648 Lowes Semi V
27hp Mud Buddy Longtail
20mph Solo Rider
17-18 Mphtwo with gear
Wed Sep 21, 2016 7:07 pm
1648 Lowes Semi V
20mph Solo Rider
1448 monarch,flat bottom with gunnels
25hp Kohler Command
Worn 9x7
20mph solo
15mph 2 people with alot of gear
Hull about 200lbs,tools 60lbs,spare homemade outboard motor just incase weighs about 100lbs
Passenger weighs 180lbs,I weigh 170lbs.
Installing a tach cause I think my rpm in water is low.
Wed Sep 21, 2016 7:23 pm
Thu Sep 22, 2016 8:26 am
Old boat:
17 x 45 Geaux Custom
25 HP Kohler 25 GDLT
Don't remember prop size
Don't know RPM
Only me (205) Empty load 24-25 mph
3 man hunting load 17-18 mph
Thu Sep 22, 2016 8:40 am
Thu Sep 22, 2016 11:13 am
Nah, we just toss some water at his boat to watch his eyes get really big [SMILING FACE WITH OPEN MOUTH AND TIGHTLY-CLOSED EYES]
Thu Sep 22, 2016 11:18 am
Heres redlines load(no pun intended)
When i left the dock today
And after a dead battery in lake long the spare motor chugged me outta lake long.
Just slide the 25 over.
Sat Sep 24, 2016 6:55 pm
A solar charger?
Sun Sep 25, 2016 1:27 pm
Helps keep the battery charged up,it can fully charge a dead battery in 8 hrs.....only if theres sunshine.
Sun Sep 25, 2016 1:35 pm
That's the most interesting load out I've ever seen
Mon Sep 26, 2016 4:04 pm
Users browsing this forum: Google [Bot] and 115 guests
