It is currently Thu Jul 03, 2025 9:38 am
Reply to topic  [ 8 posts ]
 Shop Built SD (Kind of)
Post Shop Built SD (Kind of)
I have known for a while my budget (wife) would not allow a SD to be purchased new so I have decided to build one with the help of a MB lower I picked up a year ago.
Here is my progress for now, still trying for figure it out, but I'm coming along.
Started with the 27" MB lower I picked up from a user here.
After looking for a housing or a 8"x2" rectangle tub with no luck, I decided to weld one up. I'm not a welder so all the seams will need to be ground and smoothed.
After a search on McMaster & Carr I found the timingbelt and gears for the MB lower and from Harbor Freight a new predator motor.
I just started on the transom mount (again building from scratch, and welds are definitely not pro quailty.)
I should be able to start bolting everything together this week to see about fitment and alignment as most all the parts are here.
Minimum wage jobs are for minimum experienced people.
Sat Nov 19, 2016 6:28 pm
Post Re: Shop Built SD (Kind of)
I have a mounting plate for the power head (small block) off a MudBuddy HD that I can part with. Let me know if u need it
Sat Nov 19, 2016 7:08 pm
interested to see how this bad boy turns out.
Mon Nov 21, 2016 2:24 pm
I got the Motion Base mocked up and aligned.
Now I'm waiting on the darn Woodruff Key forthe lower gear. Having issues finding a metric key.
Mon Nov 21, 2016 4:37 pm
I'm gonna go ahead and follow this. Good luck.
Tue Nov 22, 2016 5:13 pm
I ran into my first major design snag.
Maybe I have not noticed it in other engines, but the mounting plate is off center to the shaft of the motor by about 3/4".
This doesnt make a large difference in the overall idea I have in my brain, but definatly frusterating it didn't initially work as expected for further progress last night.
Wed Nov 23, 2016 9:07 am
Is that steel your making the frame out of? That's going be 1 heavy bitch!
Wed Nov 23, 2016 11:33 am
The GoDevil Surface Drive frame, transom mount, and outdrive are 100% plate steel, and no heavier than the competition. This one will be just fine.
-Custom pool noodle
-stage 4 water wings
Fri Nov 25, 2016 4:06 pm
Users browsing this forum: No registered users and 59 guests
