Re: 22hp predatpr mods and top speeds
That boat might be a little hairy with the 22hp. Just expect it. Hopefully you have tall / deep sides.
Did you get the swamp runner frame new?
You should go to their website at MudMotorKit.com and contact the owner (Jon Dobbs) and get setup with access to their web forum. He really knows his product, and they have great customer service. You'll have to provide the frame serial number for forum access.
Lots of guys running that setup at 25-30 MPH on non-mud motor specif boats. Just run of the mill jon boats and wooden boats.
I had one of their kits with the 22hp and a 6.5hp. Was quite pleased. You won't get much love for them at this forum, but they are great for what they are made for and their price. Definitely check out the forum on their web page.
With that said...here is what I would do.
By pass the govenor. It'll hold run 3800-4000RPMs in the water.
Take off the air filter housing. Cut away all the extra metal bracing around the air filter and underneath it.
Pull the carb. Work the intake adapter and carb. Get rid of the casting marks and imperfections. Gasket match the intake and adapters. It'll have a much better throttle response after that.
Gut the exhaust if you want. Or get creative and build something custom. I dont recommend this company (Mud Skipper) but they started selling this.
http://mud-skipper.com/index.php/access ... model.html I cant tell you anything about it. Its just one of the few after market products available for these motors. A lot of the Honda GX670 Parts will fit this. I've verified start and coils, but haven't had to replace either of them.
My motor has 150+ hours on it now, and we haven't had any trouble out of it. The valve lash has stayed correctly set somehow. I'm sure there is some room to clean up the heads, and do some conservative work to them. Haven't got their yet.
FUEL PUMP: This is important. This motor will not run at wide open throttle with the governor bypassed with the factory pump. It will starve for fuel and die. It just cant keep up. The factory pump is behind the cowling. You can replace it with a good diaphragm fuel pump, or you can add a low pressure electric pump in line with the factory. It's your call. Just be prepared to address this right out the box if you have any issues with it cutting out under wide open throttle.
That's just what comes to mind. It's a good motor. The predator is a good motor and I wouldn't hesitate to buy it again.
Good luck. Come back here, or the Swamp Runner forums if you need any help. Or shoot me a PM.
