It is currently Wed Dec 24, 2025 3:19 pm
Reply to topic  [ 58 posts ]  Go to page Previous  1, 2
 Peltier Hex Shaft for PD
Post Re: Peltier Hex Shaft for PD
yep, guys got a great shop and business, that mustang I see parked there a lot is one good looking unit!!!
i never thought about it much, but i quess mine is a piecemeal motor. that's never a good thing when it comes to options. no worries. lol
Sun Mar 31, 2019 11:43 am
If you see a black SS camaro there, then I am present lol
My gatortail is my first new motor in one. Everything else dad and I have had had all been piecemealing as well lol
Sun Mar 31, 2019 2:44 pm
Anyone swapped to hex shaft in a gen 4 25 hp prodrive ?
Sun Mar 31, 2019 9:10 pm
Here's a new stock reworked
Wed Apr 03, 2019 5:22 pm
Is that a stock PD worked to a 14.5P?
Wed Apr 03, 2019 8:44 pm
Yeah that’s a 14.5 pitch, the other letters are the initials of the owner of the prop
Wed Apr 03, 2019 9:05 pm
what's the ballpark turn around time on Baggy reworking a prop these days?
Thu Apr 04, 2019 5:02 pm
Depends on what you want done, I usually get mine back within a week or so, sometimes shorter depending on the work in the shop. He usually takes care of the commercial fisherman first if they come in since their livelihood depends on getting their boats back up and running.
Thu Apr 04, 2019 5:57 pm
That's about right. I'd say a week average but maybe I've got good timing. Last one I got PD to send to Baggy then to me. First new prop I've had him work. I usually wear down a stocker and then send it to add pitch to use it some more.
Thu Apr 04, 2019 6:47 pm
Fri Apr 05, 2019 6:33 am
^ yep
Sat Apr 06, 2019 8:12 am
Quick update- the boat is still with Sid up at Fast Duck Motors who installed the shaftw(hich unless you have a serious press you can’t do by your self- just a heads up). But, Sid ran the boat yesterday with his son after installing the new Fat Blade worked by Baggy to a 13P and he said it was running 31-32 with them in the boat. For those of you who know Sid and his son, these are not small individuals- both are over 290lbs and around 6.6. My tach decided to crap out, so I don’t have a feel for the RPM’s, but he said it was strong. He then tried the Raptor 2 three blade, and said the top end was better on the 2 blade-which I was surprised, but my guess is the three blade needs to be worked.
My guess, knowing this boat- with a 415lb load on top of standard load with me at 185- this would have been running 27- 29...So, this seems to be a solid 2-5 MPH pick up from the shaft and worked Fat Blade. That is impressive. I’ll know more after I run it personally, but this is what it sounds like.
Boat is for sale ironically in the classified ads- Trying not to sell the motor-but I will if it helps to move it.
Fri Apr 12, 2019 10:02 am
Fri Apr 12, 2019 10:18 am
Fri Apr 12, 2019 10:33 am
Fri Apr 12, 2019 10:49 am
Can someone give me the info on how to contact Baggy....seems he is the prop guru on here. I ordered a new prop from GD for my SD and would like to get my old one reworked for a spare. Thanks.
Wed May 01, 2019 10:28 pm
985-868-0103 is the shop number. Tell him you talked to Chauvin bro. I do apprentice work under Mr baggy so after he does the cupping, pitching, or whatever else he does to your particular prop, I’ll probably be the guy to do the finish on it or Mr Lee will.
Wed May 01, 2019 10:40 pm
Fri Jun 21, 2019 8:31 am
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 1 guest
