It is currently Sun Mar 29, 2026 5:17 am
[ 4 posts ] |
lagunaduck
 Rewiring GD Boat
Old GD boat wiring is getting brittle. I had to make a couple splices during last season and would like to replace the wiring. What gauge wiring do I need and how much? Any advice on this job?
| Fri Apr 10, 2009 4:05 pm |
Mudgun
Joined: Wed Jan 14, 2009 12:24 pm Posts: 746 Location: Here Be Rocks VA
 Re: Rewiring GD Boat
Scotchkote everything!
_________________ 1660 Rhino High-Side with center console 90/65 Mercury 2 stroke Outboard jet pump Run shallow, run loud.
| Fri Apr 10, 2009 5:00 pm |
deadbird8
Depends on the runs/where your battery is/what you run in the boat. 100W spots draw 8.3Amps, bilge pump- 2-4, running lights 1-2. If you control high amp stuff from a switch in the back, you may want to look at installing a relay.
Cover your connections with liquid electrical tape, if you add a piece of shrinkwrap over it you get a clean looking connection.
Check Mudd's site for spot wiring, may give you some ideas:
| Fri Apr 10, 2009 5:23 pm |
lagunaduck
Thanks for all the info. I don't have much accessories. I use a hand held spot light or hard hat light. So all I really have are the running lights.
| Sat Apr 11, 2009 8:18 pm |
[ 4 posts ] |
