It is currently Fri Mar 27, 2026 10:36 am
Reply to topic  [ 1379 posts ]  Go to page Previous  1 ... 18, 19, 20, 21, 22, 23, 24 ... 35  Next
 Kawi FXT00V "Let the good times roll"
Post Re: Kawi FXT00V "Let the good times roll"
What are you planning to do to the heads?
Wed Jan 21, 2015 6:40 am
Taking off .025 then going to p&p.
Wed Jan 21, 2015 7:41 am
Wed Jan 21, 2015 8:32 am
specialK what kind of boat are you running?
1650 express w/a 60 jet
Wed Jan 21, 2015 9:44 am
I went .030 no probs and I'm running 335 lift
Wed Jan 21, 2015 10:17 am
Wed Jan 21, 2015 11:33 am
Wed Jan 21, 2015 11:37 am
Chit man, you'll get those speeds with the stock cam! That'll be a sweet setup on that boat
PRODRIVE 1860 CC
Wed Jan 21, 2015 12:43 pm
Wed Jan 21, 2015 12:47 pm
Wed Jan 21, 2015 1:37 pm
Wed Jan 21, 2015 1:59 pm
I've held mine at 4800 WFO for 16 miles straight down the Atchafalaya River with no issues. And that was with a load of 3 people, 5 doz deks, all our hunting shit and an icechest full of food and drinks to spend the day. held 33.8-33.9 the entire way that morn. So as far as holding WFO for a long time, I think I proved that it will with that run. And didi it about a doz times like that.
Wed Jan 21, 2015 3:06 pm
Wed Jan 21, 2015 3:20 pm
No 16p. Just got my seals installed and back together. Just been busy to go run it.
Wed Jan 21, 2015 4:27 pm
So here is a question. Being that I have never installed a Mikuni before...
Can yall post some pics of how the mikuni is setup so that I can get an idea of what, if anything, happens with the existing linkage and governer arm?
As I am waiting for parts to be worked on, I thought I would start brainstorming my throttle cable and linkage connections...
Wed Jan 21, 2015 4:40 pm
You'll like it better with the cam, no doubt. Heck, I cadillac at 27 turnin' 3800 or so and that cam Banded is runnin has produced the best so far.
PRODRIVE 1860 CC
Wed Jan 21, 2015 4:46 pm
specialK from the numbers theses guys have been producing, your gonna be moving pretty darn good.
Wed Jan 21, 2015 4:52 pm
You're gonna trash all that so while you've got it apart take the flag off the gov arm and replace the back screw with red locktite. I put a piece of rubber hose and a clamp on the outside just to limit any further movement.
PRODRIVE 1860 CC
Wed Jan 21, 2015 4:53 pm
Wed Jan 21, 2015 5:11 pm
Leave the gov shaft, the screw and hose w/ clamp holds it so you're using what's there for sealing. You'll be removing ALL the gov arms (inside and out) and the plates/bearings that are attached to the cam itself
PRODRIVE 1860 CC
Wed Jan 21, 2015 6:29 pm
I gotcha now. I saw on the BPS site that it was removed when changing a cam and replace with a bolt.
Thanks Bug!
Wed Jan 21, 2015 6:50 pm
Did y'all have trouble getting the cam guy on the phone? I have been trying since monday...
Thu Jan 22, 2015 3:27 pm
Which one? Isky is harder to reach than Dyno but he'll definately call back.
PRODRIVE 1860 CC
Thu Jan 22, 2015 7:11 pm
Does it matter which one I send it to?
I had been trying to reach Isky since Monday...
Thu Jan 22, 2015 7:29 pm
Did dyno decide they were gonna weld on the hollow cams?
Thu Jan 22, 2015 7:42 pm
After some persuasion it seems they didn't mind after all.
PRODRIVE 1860 CC
Thu Jan 22, 2015 8:00 pm
Thu Jan 22, 2015 8:06 pm
The work from Iskey was top notch.
Fri Jan 23, 2015 7:54 am
Fri Jan 23, 2015 8:30 am
X3 pretty work for sure
PRODRIVE 1860 CC
Fri Jan 23, 2015 11:12 am
This thread is making me really regret dumping more money into briggs to try and get more out of it. Should have just parted the motor out and bought a Kawi, at this point i would further ahead in the game going the Kawi route.
Burlap Brothers
Sat Jan 24, 2015 5:02 pm
Lee hows the exhaust mods been doing?
Sat Jan 24, 2015 10:37 pm
Watched the last sunrise over the dekes for this season this morning so it's on now ;)
PRODRIVE 1860 CC
Sun Jan 25, 2015 10:32 am
Well the cam was just picked up and is on its way to be Iskyfied.
Should be picking the heads up tomorrow and start to P&P while waiting for the cam to come back...
Mon Jan 26, 2015 4:31 pm
I have ran Isky camshafts and valve train parts in other types of engines for years. They build great stuff and are willing to think outside the box to get something done for you.
Mon Jan 26, 2015 6:46 pm
Many times a new thread will start with someone just coming into the MM world or maybe they've been around for awhile and finally get the itch to mod their Bitch & Shit-on engine for more carrying capacity and what not...
Well, for the vertical shaft MM's out there, the Kawasaki is the best mod you can do (period)
So quit thinking about it and kick that B&S off in the drink and bolt on a real engine. :D
Thu Jan 29, 2015 12:31 pm
Of those of you that are running the aftermarket valve springs, any of you feel with your hands the stiffness of the spring?
I really could not tell much difference when compressing the spring in one hand.
Also, did any of you not lash your brand new valves? I was considering not doing it as I had all of them marked to go back to the same location. I thought it may make more sense to run it for a while and then lash them...
Thoughts?
Thu Jan 29, 2015 2:09 pm
Thu Jan 29, 2015 2:23 pm
The way I should have put that question is "Since this is a brand new engine, and the valves are in the original locations, did it seem necessary to to SEAT or LAP the valves.
I was typing to fast and not thinking about what I was saying...
Thu Jan 29, 2015 2:43 pm
Thu Jan 29, 2015 2:44 pm
