It is currently Tue Feb 03, 2026 9:59 pm
Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
 35 hp with EFI
Post 35 hp with EFI
The EFI on the 993 Briggs starts and runs. It idles very smooth and starts in one revolution. I haven't hooked it to the computer yet but am very pleased so far.
Sat Feb 09, 2013 6:49 pm
Post Re: 35 hp with EFI
Pics?
Casey
Sat Feb 09, 2013 7:23 pm
you da man :lol:
8 foot sneak boat with 8hp go devil going Mach 1
Layout blinds and a whole bunch of decoys
Sat Feb 09, 2013 9:35 pm
Hey stu, my PayPal is ready to go! Just say when
Sat Feb 09, 2013 9:45 pm
Here are a couple of pictures before all the wiring and plumbing was done. The ECU is fastened to the rear of the belt housing. This is a complete, "closed loop" EFI with O2 sensor, block temp sensor, intake air temp sensor, mass air flow sensor, throttle position sensor, high pressure pump and fuel pressure regulator. My next step is to connect it to my computer and tune it for the best performance. As far as I know this is the first time this mod has been done on the 993. I'll add a picture of a similar kit to the one i'm using. If you contact Ecotrons tell Matt you saw the one stu did.
Oh yeah, the kit shown uses a throttle body injection system. If you look close at the pictures you will see I went with port injection.
Sat Feb 09, 2013 10:15 pm
Impressive
Sat Feb 09, 2013 11:55 pm
Sun Feb 10, 2013 12:11 am
Thats sweet.
Jay Dore
Sun Feb 10, 2013 1:11 am
Cool
Sun Feb 10, 2013 5:31 am
Nice Stu, caint wait for your review
Sooner or later we will be able to buy big block EFI's, its just when. Until, them 25's are gonna go like hot cakes
Sun Feb 10, 2013 6:47 am
bad ass!!! i wish i had the tinkering time alaska affords!!! :D
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Sun Feb 10, 2013 6:51 am
I gave up mud motors
Sun Feb 10, 2013 6:52 am
Do this and fix the case gasket issue and I will own another 35! Lol.....sweet job.
HOTSAUCE170 wrote:
Sun Feb 10, 2013 7:29 am
Sun Feb 10, 2013 11:45 am
Sun Feb 10, 2013 11:51 am
Sun Feb 10, 2013 1:06 pm
993 cc
Sun Feb 10, 2013 1:07 pm
Got it- DOOOH!
Sun Feb 10, 2013 1:20 pm
Sun Feb 10, 2013 1:23 pm
Hey buddy, when the water gets soft I want to go for a ride. When is Easter weekend? I'm thinkin Clearwater. Looks GREAT....Don
Mon Feb 11, 2013 10:05 am
Mon Feb 11, 2013 4:07 pm
Good job Stu! It looks great.
Mon Feb 11, 2013 6:08 pm
B. MacDonald
Mon Feb 11, 2013 7:16 pm
Stu, What size throttle body did you use?
Jay Dore
Mon Feb 11, 2013 10:38 pm
Did the efi on one of my motors in 2009. Was a complete kit from a manufacture that puts them on harly motors. Still have it sitting on the shelf at the shop. Set it up on an EVT vertical intake and tried it TBI and DFI. It did better with TBI. Had it installed on a motor and tested in California before shipping it here. Too many other things happening to mess with it again. Good job on your conversion.
Tue Feb 12, 2013 8:43 am
Tue Feb 12, 2013 4:32 pm
Tue Feb 12, 2013 4:45 pm
Built a wheel that bolted to flywheel. Had 38 teeth on it with 4 missing using the halls effect sensor. Used different coils as well.
Tue Feb 12, 2013 9:42 pm
Thu Feb 14, 2013 5:43 am
Stu: you should get one of these. In your creative hands it would be deadly, I'm sure: desktop 3d printer.
http://www.stratasys.com/lp/3dprinting/ ... Qgod3V8AKQ
Thu Feb 14, 2013 7:56 am
I did a short video of the engine running and loaded it to utube. I'll do another after I tune it with the computer.
[youtube]http://www.youtube.com/watch?v=8cF2xJr5qb0&feature=youtu.be[/youtube]
Thu Feb 14, 2013 11:59 pm
All of this is over my head to say the least, but that was impressive!
Fri Feb 15, 2013 12:40 am
set up a hydrolic motor to run off your out put shaft, through a gage set with a valve off the down stream side so you can tune and compare output at a given rpm. Kinda like a dyno. if you are pushing 4000psi at 3600 wot, and a adj gets you 35-- rpm at 4000psi it added hp.
Fri Feb 15, 2013 3:06 pm
Mon Feb 18, 2013 7:44 pm
Thu Feb 21, 2013 1:24 am
Here is a quick update of the project. I haven't been pushing real hard since we have almost 5 ft of ice on the rivers and lakes so it will be awhile until I can put the engine under load. The instructions for tuning are not difficult after you have read them 8 or 10 times and figured out what is meant by some of the terms. Once I had the software working in the computer it became playtime. Right away I noticed the displacement was identified as 497 cc's. I said "that can't be right" this is a 993 cc engine so I changed it.
When I started it up it looked like a diesel under load. There was a beautiful plume of black smoke from the exhaust and I could barely keep it running. DUH!!! That must be the displacement of one cylinder. I went back into the computer and reset it to 497 and it runs great. The throttle body doesn't have any mechanical idle adjustment. Since it was idling at 1500 I wanted to be able to adjust that downward. Nothing to it. The 42 mm throttle body has a stepper motor that is controlled by the ECU, so I told it to idle at 1000 and it did. Then I told it to idle at 1200 and it did that too. The 28 mm and 35 mm throttle bodies for the single cylinders use a bleed air bypass to set the idle adjustment. There are several other adjustments I will make once it is warm enough to run outside. It gets a little close in the shop if I keep it running too long and some of the settings need to be made after the engine is warm. The cowling had to have holes cut in it to allow clearance for the port injectors. If I had elected to go with throttle body injection the cowling could have been left stock and I wouldn't have had to do any machining to the intake manifold. It still would have required the adapter from the throttle body to manifold but I prefer port injection. I fabricated two covers for the two holes where the injectors poke through the cowling because quite a bit of cooling air was escaping.
Those of you that are into hopping the single cylinder engines I encourage you to look at what ECOTRONS has for these engines. Of particular interest should be the EFI-Turbo kit. With adequate crank, rods, piston and cam I think doubling the hp is feasible without turning it into a grenade and still maintaining a reasonable idle.
More to come when the water gets soft.
Wed Mar 06, 2013 12:40 am
1850 Uncle J
Delta Performance level 4 GTR
Wed Mar 06, 2013 1:34 am
This is fantastic and appears that the kit is $599 and you pick your throttle body. Any body else thinking what I'm thinking. Why the hell can you get an entire EFI kit WITH throttle body for $599 and that mikuni carb kit is $775. Something wrong there.
Wed Mar 06, 2013 5:49 am
Wed Mar 06, 2013 7:07 am
Looks good man. Wish I had the time to tinker with a project like this. My only question: did you get warren cocos good graces to mod his motor? Lol
17*38 Klibert 23GDLT
Wed Mar 06, 2013 9:11 am
