It is currently Sun Apr 12, 2026 2:01 pm
Reply to topic  [ 18 posts ]
 Anti sieze on exhaust bolts
Post Anti sieze on exhaust bolts
How many of y'all are using anti sieze on exhaust bolts when installing new exhaust?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
1854 GTB Extreme 35GTR
Mon May 13, 2013 9:35 am
Post Re: Anti sieze on exhaust bolts
I don't
Mon May 13, 2013 9:40 am
I put locktite on mine
1648 gd hull flying in front of a stage 3 with fpr
Mon May 13, 2013 1:18 pm
i put it on mine but they will not stay tight now.
Uncle J's Custom Bow Fishing Rig 20/72 30" Sides, Calens Modded Dual GTR's
Boat Name: The Gar Barge
Team Name: Southern Stickers
18/58 Uncle J Custom 3/16 bottom 24" sides w/catwalks 6' front deck with another GTR Pushing it.
17/54 Gator Trax 35 Mud Buddy W/All aluminum FPR Mod SOLD
Mon May 13, 2013 2:25 pm
To hell with bolts! use studs and nuts, you'll double your chances of getting your exhaust off with out breaking something!
Mon May 13, 2013 2:44 pm
What size ? That sounds like a pretty good idea
Mon May 13, 2013 3:37 pm
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Mon May 13, 2013 3:42 pm
1850 & 36pd
Mon May 13, 2013 3:51 pm
M8 X 1.25 x 40mm long.
Might check with the boat Dr, They were known for selling them. They have an allen insert on one end so that you can hold it from turning.
Mon May 13, 2013 4:09 pm
Here is a 7 piece set on Ebay ( good to have and extra just in case you do loose one). And look it even comes with never-sieze! lol
http://www.ebay.com/itm/7-Piece-M8-x-1- ... 8072372%26
Mon May 13, 2013 4:28 pm
Tue May 14, 2013 5:17 am
Yep
Tue May 14, 2013 11:26 am
Did you loctite the threads, or what keeps the nuts from backing off? Bout to pull block and change gasket and that looks like a viable option.
Tue May 14, 2013 11:28 am
Tue May 14, 2013 1:17 pm
Anti-seize with drilled bolt heads and safety wire.
Tue May 14, 2013 3:01 pm
Preston, did you helicoil it before putting those studs in?
Wed May 15, 2013 5:13 am
I may go this route the next time the exhaust comes off. It a bps so it will be back off in 20 or so hours to be welded again.
Wed May 15, 2013 5:52 am
Wed May 15, 2013 5:58 am
