It is currently Fri Oct 09, 2026 6:56 pm
Reply to topic  [ 22 posts ]
 Grass screen
Post Grass screen
Anyone ever had the grass screen catch on the plastic cowling and break the three studs that hold it on to the fly wheel? Then rip the fan to shreds? Had to order the new parts today. Heard that this is a common occurrence with the 35.
1846 GTB with GTR 35
Tue Jul 30, 2013 7:05 pm
Post Re: Grass screen
Yep. You must have been the other boat at Seminole.
Broke 2 of the 3 studs on the fun run.
My solution. No more spinning guard.
Tue Jul 30, 2013 7:23 pm
Happened to mine a while back
35 GTR - 1754 Extreme
Tue Jul 30, 2013 7:24 pm
Smart thinking Mr. Triple b. That will serve the same purpose without that stuff spinning. Probably gonna do mine like that before it happens.
Sent from my DROID RAZR using Tapatalk 2
HOTSAUCE170 wrote:
Tue Jul 30, 2013 7:28 pm
You know damn well you're gonna have to shoot some paint on those zip ties before you're happy with that setup! I'll let you borrow some dead grass green paint. Only takes a week to dry. :)
Tue Jul 30, 2013 7:33 pm
Tue Jul 30, 2013 7:35 pm
I ordered a new fan and had Boat DR cut down some new studs. I'm gonna do my screen like you did bbb. Andy said you need to keep the metal ring and three studs in place to help support the fan. I'm going to try and get the broke off studs out with a left hand drill bit.
Tue Jul 30, 2013 7:48 pm
I was able to drill a small hole into the broken stud and used a tap on the drill in reverse and backed the sheared bolt out. I got lucky they weren't in there too tight. Then put the ring back on and found 3 bolt screws with the same thread.
Looked for the black zip ties for 10 minutes and settled on those as I was headed to the lake again. See my boat doesn't sit out in the driveway 4 days waiting for the paint to dry.
While I was on the lake I found the black zip ties in my dry box.
Thinking about powder coating the guard. ;)
Tue Jul 30, 2013 8:23 pm
Tue Jul 30, 2013 8:27 pm
The torx bolts that hold the screen on are the same size as the tower bolts. I used them to hold the metal ring on the fan, & put the grass screen on the inside of the cage with small black zip ties. A quick rattle can job, & it looks just like stock.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Jul 30, 2013 8:34 pm
That's why y'all stupid mofo should have a PD. :lol:
Tue Jul 30, 2013 8:37 pm
Tue Jul 30, 2013 8:57 pm
I turned the motor off as soon as I heard it go but it was too late. It didn't break any of the fins but chewed them up pretty bad.
Wed Jul 31, 2013 12:50 am
U need to leave the metal band and 3 bolts that hold the cooling fins down n the middle. The fins will flex out when running and rub the shroud if u don't. U need to cut down the center bolts so they are only buttons r they will eventually shear off too. Just get rid of the grass guard completely.
18'x54"CC Hanko/ 36PD
Wed Jul 31, 2013 4:06 am
I saw a post on here a long time ago where a vertical did the same thing except it messed up the fan, a coil and busted the main shroud. I went home that night and took all that crap out including the grass catcher. Everybody I know personally had done it.
Wed Jul 31, 2013 5:02 am
Cut those long studs off like a typical bolt head and put em back in there.
Wed Jul 31, 2013 5:04 am
Why do you need the grass catcher? I just took mine off completely.
Wed Jul 31, 2013 8:37 am
raffia from the blind gets sucked in from time to time.
1744 floating a 23 MBHD Stage 2
Wed Jul 31, 2013 8:47 am
Wed Jul 31, 2013 9:31 am
Ouch!!!!
Wed Jul 31, 2013 9:33 am
Wed Jul 31, 2013 10:17 am
Wed Jul 31, 2013 10:18 am
