Colbeans
 Anyone else had this problem
I own a gtr35 and the oil cooler is leaking on the side of the motor anyone else ever seen this happen?
| Sat Feb 01, 2014 6:47 pm |
dirtybird29+
Joined: Mon Feb 15, 2010 8:03 pm Posts: 393 Location: South Carolina
 Re: Anyone else had this problem
Yep more than likely if you pull the hoses off at the oil cooler and tighten up the barbed fittings,it will prolly fix your problem. I had this problem also.
_________________ 1854 GTB Extreme 35GTR
| Sat Feb 01, 2014 7:09 pm |
cupped up
Joined: Tue Jun 05, 2012 7:25 pm Posts: 4205 Location: St. Amant, LA
Or the cooler itself is cracked. Clean it up and look real good. I had a barb fitting I had to fix and an oil cooler cracked another time
| Sat Feb 01, 2014 7:24 pm |
missile
Joined: Mon Jun 18, 2012 7:33 pm Posts: 681 Location: DeKalb, Texas between the rivers
Same as cupped up had both places leak.
_________________ Uncle J's Custom Bow Fishing Rig 20/72 30" Sides, Calens Modded Dual GTR's Boat Name: The Gar Barge Team Name: Southern Stickers
18/58 Uncle J Custom 3/16 bottom 24" sides w/catwalks 6' front deck with another GTR Pushing it.
17/54 Gator Trax 35 Mud Buddy W/All aluminum FPR Mod SOLD
| Sat Feb 01, 2014 7:58 pm |
Colbeans
Thanks for the info but I have something else to ask have y'all ever had to replace the trim unit and if so how did work or sound before you had to replace it
| Sat Feb 01, 2014 10:14 pm |
doubleBanded
Joined: Sun Feb 03, 2013 1:26 pm Posts: 3084 Location: Down South
Mine is doin this also. Gonna try n fix when change oil
_________________ 1852 Dfou custom 35gtr
| Sun Feb 02, 2014 9:56 am |
cupped up
| Sun Feb 02, 2014 10:10 am |
Colbeans
I've put trim fluid in it but it still sounds like nails going down a chalk board
| Sun Feb 02, 2014 2:14 pm |
Charlie-echo
Joined: Sat Aug 11, 2012 11:19 am Posts: 63 Location: Covington, LA
Mine is leaking around there too, motor has about 37 hours on it. I removed the fitting closest to the oil filter and used plumbers tape like a few guys on here suggested, but the problem is that the fitting won't tighten up enough, before it hits the block. The fitting is actually too long . Not sure how to fix that!
_________________ 2013 1854 Gator-Tail Extreme center console w 35 GTR
| Sun Feb 02, 2014 2:59 pm |
Colbeans
I found today that it is the oil cooler that is leaking it has a hairline crack in it
| Sun Feb 02, 2014 4:51 pm |
Bigrich
Joined: Wed Dec 19, 2012 7:52 pm Posts: 7064 Location: Mallard country
| Sun Feb 02, 2014 4:56 pm |
schauv01
Joined: Wed Oct 03, 2012 6:50 am Posts: 565 Location: Union, LA
Yep! Had same problem
| Sun Feb 02, 2014 6:47 pm |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
| Sun Feb 02, 2014 7:01 pm |
Colbeans
Y'all know what size the stock one is?
| Sun Feb 02, 2014 9:06 pm |
msm8281
| Sun Feb 02, 2014 9:10 pm |
