It is currently Fri Feb 13, 2026 2:26 am
Reply to topic  [ 15 posts ]
 Anyone else had this problem
Post Anyone else had this problem
I own a gtr35 and the oil cooler is leaking on the side of the motor anyone else ever seen this happen?
Sat Feb 01, 2014 6:47 pm
Post Re: Anyone else had this problem
Yep more than likely if you pull the hoses off at the oil cooler and tighten up the barbed fittings,it will prolly fix your problem. I had this problem also.
1854 GTB Extreme 35GTR
Sat Feb 01, 2014 7:09 pm
Or the cooler itself is cracked. Clean it up and look real good. I had a barb fitting I had to fix and an oil cooler cracked another time
Sat Feb 01, 2014 7:24 pm
Same as cupped up had both places leak.
Uncle J's Custom Bow Fishing Rig 20/72 30" Sides, Calens Modded Dual GTR's
Boat Name: The Gar Barge
Team Name: Southern Stickers
18/58 Uncle J Custom 3/16 bottom 24" sides w/catwalks 6' front deck with another GTR Pushing it.
17/54 Gator Trax 35 Mud Buddy W/All aluminum FPR Mod SOLD
Sat Feb 01, 2014 7:58 pm
Thanks for the info but I have something else to ask have y'all ever had to replace the trim unit and if so how did work or sound before you had to replace it
Sat Feb 01, 2014 10:14 pm
Mine is doin this also. Gonna try n fix when change oil
1852 Dfou custom 35gtr
Sun Feb 02, 2014 9:56 am
Sun Feb 02, 2014 10:10 am
I've put trim fluid in it but it still sounds like nails going down a chalk board
Sun Feb 02, 2014 2:14 pm
Mine is leaking around there too, motor has about 37 hours on it. I removed the fitting closest to the oil filter and used plumbers tape like a few guys on here suggested, but the problem is that the fitting won't tighten up enough, before it hits the block. The fitting is actually too long . Not sure how to fix that!
2013 1854 Gator-Tail Extreme center console w 35 GTR
Sun Feb 02, 2014 2:59 pm
I found today that it is the oil cooler that is leaking it has a hairline crack in it
Sun Feb 02, 2014 4:51 pm
http://bakerprecision.com
Sun Feb 02, 2014 4:56 pm
Yep! Had same problem
Sun Feb 02, 2014 6:47 pm
http://www.bakerprecision.com/trucool.htm
Sun Feb 02, 2014 7:01 pm
Y'all know what size the stock one is?
Sun Feb 02, 2014 9:06 pm
Sun Feb 02, 2014 9:10 pm
