It is currently Wed Feb 11, 2026 4:59 am
Reply to topic  [ 15 posts ]
 2011 Mud Buddy 35hp NON-CDI RPMS?
Post 2011 Mud Buddy 35hp NON-CDI RPMS?
I'm a new owner of a used mud buddy 35 hp non cdi with stage 1 mods.
Today I ran the motor for a good hour or so, but when i would hit WOT it seemed like it hit the rev limiter, when i trimmed the motor down some it would level out at 4330. So my question is what rpms should I be running at WOT?
35hp Mud Buddy Stage 1 pushing 15x44 Gator Trax W / Hunt Deck
Mon Feb 03, 2014 3:47 pm
Post Re: 2011 Mud Buddy 35hp NON-CDI RPMS?
Stock carb? Or Mikuni?
Mon Feb 03, 2014 3:52 pm
Mikuni
Mon Feb 03, 2014 3:53 pm
Used motor , how worn is your prop ?
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
they both measure at about 12.25 but the second has that big chip out of from the pervious owner hit a rock.
Mon Feb 03, 2014 4:05 pm
Mon Feb 03, 2014 4:07 pm
Non-cdi with a mikuni should have a 5100 rev limiter on it. How high will it rev in neutral?
Mon Feb 03, 2014 4:35 pm
The highest i've seen in the last few runs is around 4550..
Mon Feb 03, 2014 4:42 pm
No, in neutral, how high will it rev?
Mon Feb 03, 2014 4:46 pm
Oh my bad 4640
Mon Feb 03, 2014 5:30 pm
From your first post, I thought it was cutting out on you at 4300. What did you mean about leveling off when you let off the throttle?
Mon Feb 03, 2014 5:43 pm
4640 is out of water in neutral, 4330 is prop in water in gear. I was wondering if my rpms should be higher or lower. Or if it's safe at what I'm running
Mon Feb 03, 2014 6:20 pm
Mon Feb 03, 2014 6:24 pm
Your safe at 4300. Much more than that though, and you will need to verify that your valve springs are shimmed so you don't float a valve. I'm assuming you have IM heads on the motor, so they should be shimmed, but it won't hurt to check. Check your lash while you have the valve covers off.
Mon Feb 03, 2014 10:27 pm
