It is currently Tue Mar 24, 2026 3:52 pm
Reply to topic  [ 6 posts ]
 Go devil 23 hp idle problem
Post Go devil 23 hp idle problem
What is the rpm idle suppose to be out of the water I am only getting 1000 rpm any info will help the motor don't even have 5 hours on it yet but I when I put it in the water it wants to die when under load on idle I have kept it around 1150 r 1200 with my hand on throttle
Fri Feb 14, 2014 7:31 pm
Post Re: Go devil 23 hp idle problem
It won't die on idle once it's warm, you can adjust the linkage. I have mine set to idle around 1200 out of water and it will turn up to 4300 or so.
Fri Feb 14, 2014 7:34 pm
I had mine running between 850 and 900 in water. I like to keep it as slow as possible and still run on water
40HP Gatortail
Fri Feb 14, 2014 7:48 pm
I usally let the motor run the whole time I am getting the boat ready then when have it in the neutral position it's when I am lowering it in to water the rpm go to 750 and it wants to die but I am gonna let go devil fix it and 1200 out of water what does it run in the water 1000 1050 rpm just curious thanks guys
Fri Feb 14, 2014 8:24 pm
I think I saw like 1040 or 1070 this afternoon. Just depemds
Fri Feb 14, 2014 9:05 pm
Thanks man that really helps a lot man
Sat Feb 15, 2014 6:10 am
