It is currently Tue Mar 24, 2026 3:52 pm
[ 6 posts ] |
Go devil 23 hp idle problem
Go devil SD man
What is the rpm idle suppose to be out of the water I am only getting 1000 rpm any info will help the motor don't even have 5 hours on it yet but I when I put it in the water it wants to die when under load on idle I have kept it around 1150 r 1200 with my hand on throttle
| Fri Feb 14, 2014 7:31 pm |
cmk07c
Joined: Thu Jul 21, 2011 9:11 am Posts: 556 Location: Metairie, LA
 Re: Go devil 23 hp idle problem
It won't die on idle once it's warm, you can adjust the linkage. I have mine set to idle around 1200 out of water and it will turn up to 4300 or so.
| Fri Feb 14, 2014 7:34 pm |
WhoDat88
Joined: Thu May 23, 2013 4:24 pm Posts: 2912 Location: Thibodaux, La
I had mine running between 850 and 900 in water. I like to keep it as slow as possible and still run on water
_________________ 1850 Predator Series Stick Steer Option 40HP Gatortail
| Fri Feb 14, 2014 7:48 pm |
Go devil SD man
I usally let the motor run the whole time I am getting the boat ready then when have it in the neutral position it's when I am lowering it in to water the rpm go to 750 and it wants to die but I am gonna let go devil fix it and 1200 out of water what does it run in the water 1000 1050 rpm just curious thanks guys
| Fri Feb 14, 2014 8:24 pm |
cmk07c
I think I saw like 1040 or 1070 this afternoon. Just depemds
| Fri Feb 14, 2014 9:05 pm |
Go devil SD man
Thanks man that really helps a lot man
| Sat Feb 15, 2014 6:10 am |
[ 6 posts ] |
