It is currently Sun Jun 22, 2025 9:09 pm
Reply to topic  [ 28 posts ]
 missing governed idle tab spring
Post missing governed idle tab spring
My 2013 35hp gdsd idles rough then quits when it is tilted up and I noticed today I am missing the governed idle tab spring .... could this be my issue? It idles fine when it is down but when it's tilted up it begins to bounce between high and low rpms then quits
Tue Feb 17, 2015 9:33 am
Post Re: missing governed idle tab spring
i think this picture has become the standard - better track down that spring
Tue Feb 17, 2015 10:11 am
Does Briggs have a replacement or should I call godevil
Tue Feb 17, 2015 11:17 am
Yes and yes
- Mark Twain
Tue Feb 17, 2015 12:14 pm
That spring helps maintain idle when put under instantaneous load (like engaging the clutch or in your case dropping the prop in the water). It wouldn't have anything to do with the motor position and keeping a consistent idle. Do you have some type of mercury switch on it?
Tue Feb 17, 2015 1:06 pm
There is a mercury switch just for the starter .. just ordered the spring see if it helps any who knows
Tue Feb 17, 2015 3:03 pm
we've seen some weird things fixed by installing that spring, hopefully it helps - at least it is cheap
Tue Feb 17, 2015 3:20 pm
Hopefully.. I will let you guys know if it helps here in a few days once I get it in the mail
Tue Feb 17, 2015 4:12 pm
Wed Feb 18, 2015 4:46 am
not sure better put up a picture - here's the Briggs parts list
part numbers
Wed Feb 18, 2015 7:26 am
Can't really tell in the part diagram doesn't seem like it is pictured but if u look at the picture you posted it's to the right of the red arrow for governor spring the purple spring .... there is two eyelets right there and I have a spring connecting those two
Wed Feb 18, 2015 9:29 am
I don't know - DB8 knows a LOT more than me, did you call GD and send them a picture? Post a pic worth a 1000 words
this is why I tore this off my motor and went EFI
Wed Feb 18, 2015 1:11 pm
Ok I will post a picture soon
Wed Feb 18, 2015 2:50 pm
I'm missing one of those springs as well. But I'm afraid to change anything because it idles and runs just fine
Wed Feb 18, 2015 6:18 pm
Which one are you missing
Wed Feb 18, 2015 7:09 pm
I'll have to take a pic, I looked at it right when I got it, then stopped worrying about it after I realized it wasn't causing any problems
Wed Feb 18, 2015 9:07 pm
Refurbishing a Prodrive
Wed Feb 18, 2015 10:18 pm
Thu Feb 19, 2015 7:59 am
Thu Feb 19, 2015 2:01 pm
Thu Feb 19, 2015 2:42 pm
Thu Feb 19, 2015 7:25 pm
Ok ... once I get a day off and it's not negative 30 out I will have to check .. is that governor supposed to bounce the throttle up and down ? seems like I have excess slack in my throttle cable as well ..
Fri Feb 20, 2015 4:43 am
Well I finally fixed my motor ... after struggling during duck season to idle In neutral ... I increased the idle on the carb back in October but didn't realize that there was an idle spring on the governor that needed to be 50 or 100 rpms above the idle setting on the carb or else it's all screwed up .... think the idle was set at like 800 on the governor spring and 1200 on the carb ...
But I got the tab bent out to 1300 rpms and my carb setting at 1200 ... I can tilt the motor up now all I want and it idles great and the governor keeps it regulated
Mon Feb 23, 2015 4:54 pm
Using Tapatalk
Tue Feb 24, 2015 9:37 pm
Yea it's great now ... it was 0 degrees with a windchill that had to be at least negative 10 while I was doing this but it started very easy and warmed up just fine without kicking out despite the cold
Wed Feb 25, 2015 4:38 am
good to hear - you can help the next poor guy out, we see a couple of these a month it seems
Wed Feb 25, 2015 1:45 pm
Yea will do .. very easy fix as I found out but a major pain in the ass If you don't know what it is haha
Wed Feb 25, 2015 2:49 pm
Users browsing this forum: Google [Bot] and 188 guests
