It is currently Tue May 28, 2024 11:03 pm
Reply to topic  [ 11 posts ]
 Mudbuddy trim not working
Post Mudbuddy trim not working
The Mercury trim on my Mudbuddy quit working. When I hit the button for either up or down, there is a buzzing sound coming from the relays. I pulled the relays and tested them and supposedly they are good. One buzzes one kinda makes a "ratchet" sound. Any suggestions?
2012 1754 GT Hunt Deck Hybrid Rake
2012 Mudbuddy 45 Vanguard HD Mag Sport, Marshmellow exhaust, Mikuni carb
Sat Dec 09, 2017 6:26 pm
Post Re: Mudbuddy trim not working
Make sure the battery has a good charge and check your connections. It sounds like they are not getting enough power.
Sat Dec 09, 2017 6:39 pm
Battery fully charged. I did notice some burning plastic/electrical smells a few time while I was out (just before it quit working). But I figured that to be my buddy's boat.
Sat Dec 09, 2017 7:55 pm
Check the wires that feed them for loose connections. I have seen bad connections where the wire meets the connectors. They will look good but the wire will be corroded where it meets the connector. Wiggle the wires at the connectors at the battery while trying to operate the trim and see if will try to work.
Sat Dec 09, 2017 8:15 pm
If relays are good,check football up n down switch connections also,it does sound like a wiring problem to me says Ronbow
Gator Trax 16/50 ---HDR Black Death 4500 BPS SWAMP STAFF
Sun Dec 10, 2017 8:42 am
Jumped the wires to the trim motor. Motor works fine. I am assuming the switch works if the relays are getting electricity to make noise.
Sun Dec 10, 2017 2:09 pm
Sounds like the relays then. Do the mud buddy's have relays? I figure they would have gone to an up/down switch with the built in relay like gator tail uses nowadays.
HOTSAUCE170 wrote:
Sun Dec 10, 2017 2:22 pm
If they are both chattering I still think it's a bad connection. Check your ground wire coming from the relays.
Sun Dec 10, 2017 4:53 pm
It was the circuit breakers. Replaced both and it works great.
Sun Dec 10, 2017 7:19 pm
Glad you got it figured out.
Tue Dec 12, 2017 7:03 pm
If problem developes again with new circuit breakers, you may need to take trim motor off resivour and dump water out of it. Have worked on two trim units this past year that water had got into trim motor. When temps were down moisture in motor would freeze and lock motor up, kicking circuit breakers out. Eventually circuit breakers would fail, from continued tripping. We used brake cleaner to flush out motor and used compressed air to blow out motor, and then RTVed every seam and around bolts.
Wed Dec 13, 2017 8:45 am
Users browsing this forum: No registered users and 255 guests
