It is currently Tue Sep 23, 2025 3:27 am
[ 7 posts ] |
Manually roll the motor over
dsw1000
Ok this may get me beat up but how do you manually turn the motor over to set the valve lash? I found all the posts for setting the lash but everybody just says roll the motor over. I set the motor in fwd gear and turn the prop but the valves never move. What am i missing?
Mon Dec 25, 2017 10:09 am |
Will C
 Re: Manually roll the motor over
Turn key on to engage clutch? Remove spark plugs also
Mon Dec 25, 2017 10:15 am |
ibfishinb
What will said.
Mon Dec 25, 2017 7:46 pm |
dsw1000
Mon Dec 25, 2017 7:51 pm |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
LMAO!!!! Its the simpler things in life that are entertaining and sometimes it is the solution!
BTW According to chemistry, alcohol is a solution!!!
OH! and don't forget to turn the key off when you get finished, so you don't run down your battery like I did!!!
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
Tue Dec 26, 2017 9:49 am |
Smoke
Joined: Fri Jan 23, 2009 1:27 pm Posts: 1095 Location: SW Michigan
_________________ 1854 Prodigy Open HDR/Stage 3 mods Prodigy Boats Pro Staff BPS Swamp Staff Member Blackwater Marine LLC.
Tue Dec 26, 2017 11:26 am |
Russ
Tue Dec 26, 2017 7:25 pm |
[ 7 posts ] |
