It is currently Mon Sep 22, 2025 11:35 pm
Reply to topic  [ 7 posts ]
 Manually roll the motor over
Post Manually roll the motor over
Ok this may get me beat up but how do you manually turn the motor over to set the valve lash? I found all the posts for setting the lash but everybody just says roll the motor over. I set the motor in fwd gear and turn the prop but the valves never move. What am i missing?
Mon Dec 25, 2017 10:09 am
Post Re: Manually roll the motor over
Turn key on to engage clutch? Remove spark plugs also
Mon Dec 25, 2017 10:15 am
What will said.
Mon Dec 25, 2017 7:46 pm
Mon Dec 25, 2017 7:51 pm
LMAO!!!! Its the simpler things in life that are entertaining and sometimes it is the solution!
BTW According to chemistry, alcohol is a solution!!!
OH! and don't forget to turn the key off when you get finished, so you don't run down your battery like I did!!!
Tue Dec 26, 2017 9:49 am
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Tue Dec 26, 2017 11:26 am
Tue Dec 26, 2017 7:25 pm
cron
