It is currently Fri Mar 20, 2026 1:28 pm
[ 6 posts ] |
war eagle pd rig need pods???
kwacksmacker40
running a 1648 war eagle with 32 pro drive. Motor is way too heavy. Have to put absolutely everything and everyone in front of the boat to plane out. Nearly impossible by myself. Wondering if a set of pods would fix this. From what i can tell the only problem would be you couldnt use reverse. Any ideas would help thanks
| Tue Oct 12, 2010 11:22 pm |
dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
 Re: war eagle pd rig need pods???
12 x 12 bennet trim tabs may be your answer. Check for clearances for the swivel foot to reverse before you install.
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
| Wed Oct 13, 2010 6:57 am |
Gigafowl
You already know the problem - the boat is too short - a pair of 12" pods would NOT provide more floatation than 6" of extra hull length and you want / need a 2' to 4' longer hull....
Sell the hull - sell it fast before the MM hammers the value out of it....
Get you a longer hull - preferably specifically built for the motor you have....
| Wed Oct 13, 2010 7:18 am |
greenhead
Joined: Wed Aug 11, 2010 5:46 pm Posts: 66 Location: Middle of California
_________________ 1748 pd boat w/ 36pd hht & fpr
| Wed Oct 13, 2010 9:11 am |
MGlickLBZ
Joined: Sun Oct 24, 2010 7:40 am Posts: 1 Location: Reedsburg, WI
Gents, I'm in the same situation. I have a Alumacraft waterfowler 16 and the bottom width is 50". I have a Prodrive 36 on it. Boat will plane out but would like more floatation for shallow water. Are the pods from Beavertail worth it? I can't spend anymore money for this year for a new boat, trust me I would love one.
| Tue Oct 26, 2010 2:33 pm |
caddobrook
Pod provide about 200 lbs of lift to back of boat.
If you think that will help your problem, then go for it.
It is much better to sell you boat and get one that is designed for a mm.
If that is not possible, then you can try pods.
I have a 1648 with a 32 pd and added pods because 1) didn't know any better at the time and 2) didn't want to spend the money on a new boat. But at least my boat was a slick bottom boat designed for a mm. Did lose reverse. No way to make that work.
My main issue was the back end sat so low it would swap even with a sharp turn.
Pods fixed me right up, and I am very happy with them.
IF you decide to do pods, I would suggest getting someone to custom build them for your boat, and weld them on. Poorly designed/installed pods can hurt you.
good luck.
| Tue Oct 26, 2010 2:50 pm |
[ 6 posts ] |
