It is currently Mon Apr 06, 2026 10:52 pm
Reply to topic  [ 13 posts ]
 pods question
Post pods question
I was running a 25 hp lt. I just bought a 35 hp sd. I dont know if its a mental thing or what but it seems to draw more water in the back than before. Since most of my hunting is done on hard bottom instead of mud I was wondering if pods would benifit me. My boat is the 1845gd. What are the pros and cons for pods? I stepped up to the sd to gain speed. Will I lose some of it if i go to the pods? Do they help starting out in hard bottom skinny water? Any help would be very appreciated. thanks
Sun Oct 31, 2010 4:24 pm
Post Re: pods question
Its sittin lower because this motor is heavier.
A 18x54 should be more than enough to float it properly.
pods are ment to be used on a boat that was too short to support the wieght, it gives more lift near the motor
How fast are you running now?
post some pics of your rig.
Sun Oct 31, 2010 4:38 pm
I'm running 25 mph with me 300 lbs and one other guy 245lbs and with 2 other guys and gear was about 21 mph. It's not that it dosen't float right just wondering if it would help me run skinner in the water with hard bottom.
Mon Nov 01, 2010 2:46 pm
Just run it how it is. Pods will kill your reverse, shorten da amount you can turn your motor, and force da boat to run too flat killin you speed. Your boat is a good size for dat motor. Just enjoy it and kills sum ducks.
Mon Nov 01, 2010 3:24 pm
I bet that boat looks like a UFO going threw the marsh with all them lights up front.
14 by 44 Weld Craft powered by a 20hp. go devil longtail
Team Arc Angel Bowfishing
Mon Nov 01, 2010 5:28 pm
is it just me, or does that boat look less than 54" at the bottom?
Mon Nov 01, 2010 6:33 pm
Sometimes it's best to just keep your fingers quiet...
Mon Nov 01, 2010 7:48 pm
He said it was a 1845....but still looks narrower than that
1850 Custom Flat wit a lil B&B Fab followed by a 36 Prodrive FPR
Mon Nov 01, 2010 7:49 pm
With 300 pounds of arse and that motor a barge might need pods :D
20x60 homemade with twin Prodrives
JH Chopper (YLM)if I have time will make a SH
Mon Nov 01, 2010 8:25 pm
Eat - Sleep - Hunt ! ! !
Mon Nov 01, 2010 8:46 pm
Its got a 12" prop on it and it also has power trim on it. I don't know if thats what you mean by other hole. Didn't notice a speed difference between 2 or 1 person. Don't get me wrong its not that its not working with boat maybe I just wanted more than was possible out of the rig. Same spot my buddy had to push his Beavertail out to get going. By the way good eyes guys didn't see it myself but its only 44 not 45. :D
Tue Nov 02, 2010 3:44 pm
The GTR has 3 holes - or pivot points - from which it can run....
The GTR guys I know like WestEndAngler can advise you better as to
what the advantages of the change of holes will do.... But I have seen
and read of significant performance changes by just swapping that lil pin
to the other hole.... If you were in the water you would reach over the
transom and down almost to the waterline to reach it - on the bottom of
the MM transom mounting bracket.... Just below your trailering bracket...
It looks like you are in the middle hole - try the bottom one - seems like
that is the one most of them like best....
It is a simple change - you might find a performance boost by experimenting
with the other 2 holes or pivot points....
Good Luck !
PS - sell me that hull before you put pods on it - LOL
Tue Nov 02, 2010 8:41 pm
Tue Nov 02, 2010 9:06 pm
