It is currently Sun Jul 20, 2025 7:36 pm
[ 6 posts ] |
Wiring Headlights(need some help)
canvasbackdrake
Joined: Mon Mar 22, 2010 8:44 pm Posts: 140 Location: Pearland, TX
I bought some LED Optronics Docking lights and needing some help with the setup? I am good with directions and have some DC current knowledge. I am trying to use a rocker switch with a ground, main power and positive plug which i never used before. The directions say to hookup the main power in the middle plug, ground(black) to the top plug, and red positive 5 amp fuse to the bottom plug and than to the battery. It is not telling me to hook up the black wire to the battery . Is that correct? Also it comes with 20g wire is that fine? It will not be enough wire for my boat, can i use 14g wire with the 20g without harming it? Thanks for the help in advance.
Mon Nov 29, 2010 9:22 pm |
cb5331
 Re: Wiring Headlights(need some help)
Where is it telling you to get ground from? Your boat doesn't have a chassis ground (or shouldn't at least) so you will have to run both pos and neg straight to the battery.
Mon Nov 29, 2010 9:25 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
The ground definately needs to go from the lights to the battery, if your rocker switch is a lighted switch, it will also need to be grounded to the battery for the backlight to work. Run a hot wire from the + post to the switch, and another hot wire from the switch to the lights. Easy install, but if ya run into trouble, hit me up, I'm in Port Arthur & can give ya a hand if needed. Better yet, bring it all with ya & come to the ride on Saturday in Port Neches.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Mon Nov 29, 2010 9:34 pm |
canvasbackdrake
thanks for the help, the directions say nothing like that. did not know about the ride this weekend, that sucks already have plans
Mon Nov 29, 2010 9:49 pm |
Chico80x
Joined: Tue Aug 11, 2009 10:55 am Posts: 743 Location: Ft. Lauderdale, FL
Make sure you put an inline fuse on the positive wire if you run the wire straight to the battery and put the fuse as close to the battery as possible.
_________________ "We Are Products Of Our Decisions"
Tue Nov 30, 2010 9:57 pm |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
what these guys said...
I have a 30amp breaker in line with my possitive wire going to my switch panel... works great.
put a fuse or a breaker
_________________ I gave up mud motors
Tue Nov 30, 2010 10:12 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 100 guests |
