It is currently Tue Jul 22, 2025 7:45 am
Reply to topic  [ 15 posts ]
 Spud pole receiver ideas
Post Spud pole receiver ideas
I was using an adaptation of a 2" rod holder as a receiver for my boat spud poles. The idea worked but the aluminum is too flexible and bends too easily. Most aluminum mud boats have these receivers integrated into the hull itself, which is not an option for my wooden boat. Any of you have good alternative ideas to share?
Sun May 15, 2011 6:24 pm
Post Re: Spud pole receiver ideas
get an aluminum boat
Mon May 16, 2011 4:39 am
Don't know u would secure them, but u should use willow poles for your spuds.
Gator tail
Mon May 16, 2011 5:43 am
One of our sponsors - Daley's has some nifty 1/2" poly spuds with
a nice T handle at the top and screw mountable adjustable recievers
that they slide into.....
Saw about 3 variations of them when I went by there Saturday
to look around for the first time....
Eat - Sleep - Hunt ! ! !
Mon May 16, 2011 7:02 am
gator trax sells some kind of flexible spud pole and brackets now.
Bayou Gun Runner
Mon May 16, 2011 7:29 am
"recycle" a couple of transom mount trolling motor brackets.
Mon May 16, 2011 8:17 am
Saw those at the Gonzales outdoor show couple months ago....very good!!
The recycled transom trolling motor bracket idea is excellent, too.
Mon May 16, 2011 10:04 am
Don't know if you saw the mount I have for the big umbrella or not. Take a 4"-5" piece of 1-1/2" alum angle & a 3" piece of 1-1/2" or 2" alum pipe & have em welded together so that you can bolt or screw the angle to your transom or gunwale & the pipe will be verticle. The one I'm using for the umbrella used to be mounted on the transom of my GD hull. Cheap & effective. ;)
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon May 16, 2011 9:14 pm
go get a peice of alum pipe 6 to 10 inches long and weld algle iron on the sides drill holes in the angle and just bolt it to your transom
18x48 homemade skiff pushed by a 2010 36 prodrive tiller drive long shaft,
camo, with hydro trim and manual reverse
Wed May 18, 2011 1:42 pm
This would accent your boat nicely!
17*38 Klibert 23GDLT
Wed May 18, 2011 3:16 pm
Wed May 18, 2011 3:18 pm
Get a cypress tree 6 to 10 inches long 6 inch od and bore a 2 inch hole in it then put root stimulater on one side and hold it against your boat for a couple of days and there you go
Wed May 18, 2011 7:46 pm
Wed May 18, 2011 8:12 pm
DGuidry make a trip to Prairieville and I will weld it up for you. I already have the pipe just need a little piece of aluminum. Or pay for shipping a piece of angle and I will mail it to you
Wed May 18, 2011 8:42 pm
Hell I may even have the angle too. Would have to dig around and see
Wed May 18, 2011 8:47 pm
Users browsing this forum: No registered users and 91 guests
