It is currently Tue Dec 16, 2025 5:50 am
Reply to topic  [ 8 posts ]
 Need pics and suggestions
Post Need pics and suggestions
Alright guys,
I've got a 16x54 GD boat with a 35GDSD with EVT intake, Mikuni carb, and EVT exhaust. I cannot run my boat with just me in it. I've talk to a few people about the porposing problems I'm having. A few people have talked about adding wedges. I also talked to Warren Coco about it. He suggested welding a bead across the bottom of the boat where the bottom meets the angled part of the transom. He also said that I could beat a hook right in front of the transom to create more drag.
Has anyone used any of these things to help bring the bow of the boat down? If so, can ya'll post some pictures so I can get some ideas.
I have already cut the bow open on my boat and mounted my 2 6 gallon fuel tanks under the bow. I'm trying to figure out how to move my battery to the bow without spending a fortune in wire and cable to get the job done. To anyone who has moved the battery to the bow, can you give me some suggestions as to what cable was used and possibly where to get it from.
Thanks,
Scooter
Wed Jul 15, 2009 1:17 pm
Post Re: Need pics and suggestions
SO (pronounced esso) cable - for 30 to 50 bucks from a good electrical supply house you can
get the cable rated for at least 20 amps AC to hook up a 2 battery system and put a small breaker box or a Perco switch in to parallel the batteries so that they will charge while running.... Use second battery for fishing lights and / or trolling motor....
It is tough and small enough diameter that you can run it in the floor down through the water channels on each side of your GD hull where you likely
already have your fuel line run.... Remove the existing motor leads and
cut SO to correct lengths - go to a truck stop and have them press on
high load terminal ends for a few bucks....
My GDSD had the same issue at 28mph or higher - battery move solved
the problem without adding any extra drag or weight to what I already
had in the boat - just relocated it...
Eat - Sleep - Hunt ! ! !
Wed Jul 15, 2009 3:11 pm
Thanks Giga. I'll look into that. My boat starts around 21 mph in deep water. I've seen 29.8 with just me in shallows. I gotta get this fixed. Lol.
Wed Jul 15, 2009 3:26 pm
i heard of people using wedges, and heard of people welding a bead, and u grind it down slowly until its right where u need the bow to be, just make a trim tab
Wed Jul 15, 2009 8:43 pm
I have a 16x60,35sd, heads decked,carb.,intake adpator and exhaust runni ng 33mph in deep water and experience no bouncing. I had a custom 12 gallon aluminum tank mounted behind the deck that extends the deck by about 5 inches. I had the tank mounted before the mods to the engine so I am not sure if that is why I have no bounce. During the summer I have trolling motor and a battery also mounted in front. Good luck!!
Wed Jul 15, 2009 9:13 pm
put sand bags in the front :lol: :lol:
Thu Jul 16, 2009 10:50 pm
fat chicks on the deck
Fri Jul 17, 2009 2:21 pm
I moved my battery to the front using remote terminals from West Marine ($20) mounted to the transom and 6 gauge SO cord ($25) that I ran down the opposite channel as the fuel line. The cord has 3 strands but I only used 2. I attached some pictures.
Sat Jul 18, 2009 10:47 am
