It is currently Fri Nov 20, 2026 8:06 am
Reply to topic  [ 13 posts ]
 Trailer question
Post Trailer question
I have a Gator Trax 3 man gator hide, and I love it. It has 4 bunks on the trailer, but we have a lot of very shallow boat landings up here and am thinking of taking them off and putting rollers on. has anybody any done this? If so what rollers did you use? I am afraid of that with the rollers on a flat bottom boat that it might start denting the bottom of the hull from going down the road and the weight of the boat not being as well distributed as it was on the bunks. But I could be wrong and that is what I want to find out.
Thanks,
Tanner Wildes
Hayward, WI
Tanner Wildes
www.wisconsinwaterfowler.com
Sun Dec 09, 2012 4:36 pm
Post Re: Trailer question
How are your bunks mounted? You need to lower them somehow. If they are on brackets, you can remove and mount to frame.
Sun Dec 09, 2012 4:49 pm
I think he wants to roll it off the trailer instead of having to push it because of shallow water.....a winch would help pull it back on. try putting some steelflex or other slick coating on the bottom of the boat, should make it slide off bunks a whole lot easier.
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Sun Dec 09, 2012 4:53 pm
Sorry, I don't think I explained it corectly. I am thinking of taking off the bunks and putting rollers on instead. I have bunks on there now, and I put those mylar pads on them, but the water is so shallow that I am in that the water is barely making it to the bottom of the boat, and its not floating at all, no part of it. I know with fishing boats that the rollers are so slick that the boat doesn't have to be in water and it will roll off no problem at all, and that is what I am thinking of doing because of the shallow water, putting rollers on in place of the bunks so it can roll off the trailer with ease.
Thanks,
Tanner Wildes
Tanner Wildes
Sun Dec 09, 2012 4:58 pm
May hook the bottom.
IT IS WHAT IT IS!
YOU BRING YOUR HOUSE DOG HUNTING?.....
Sun Dec 09, 2012 5:01 pm
Don't want to jack your thread. I'm in Wisconsin and had the same problem several times this year. I was thinking about rollers as well but am worried that on long hauls it's going to beat up the bottom of the boat. My boat is easily over 2,000 lbs loaded and pushing it off the bunks just isn't going to happen, IMO. My thought was to fabricate some retractable rollers. If you have ever seen a semi trailer for transporting trusses they have retractable rollers in the bed for off loading.
Sun Dec 09, 2012 5:04 pm
Tanner,
Are your bunks elevated from the frame on brackets? I took mine off the brackets and bolted to the frame, and I lowered it 6" or so. Do that and put a slick coating on the bottom of the boat, and you should be better off. I would be worried about doing the rollers.
Sun Dec 09, 2012 5:07 pm
i would make sure the rollers are directly beneath the runners so you dont dent the bottom over time, still i would use steel flex on the bottom of the boat to be safe....it should make it glide off that mylar.....if you do use steel flex be careful at normal steeper ramps, the boat will slide off quick. you might want to float the boat before unhooking it from the trailer in those situations.
Sun Dec 09, 2012 5:10 pm
the slick coating on the bottom works like those furniture moving pads.....makes a 2000 lb boat easy to slide.
Sun Dec 09, 2012 5:13 pm
Mount the boards directly to frame with 12 x 2.5" hex head self tapping screws. Make sure you have a high torque drill to sink the heads a little below flush.
I do this to all my personal trailers and have never had a single problem.
If you still need to go shorter, put the axle on top of springs but make sure you have large enough tires so the springs aren't too close to the ground.
If you have a GTR be careful on the height. If you use the trailering bracket and the trailer is too low then the prop and tail of the motor will be too low to the ground in low spots
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
steelflex................
Sun Dec 09, 2012 5:19 pm
or one of our sponsors that i didnt even think of ....gator glide.
Sun Dec 09, 2012 5:20 pm
I got the same problem, I can back across the river and not get the boat wet. Lower bunks, slick bottom coat and 8" rims.
1754 GTB / 35 GTR
