It is currently Fri Apr 10, 2026 11:14 am
Reply to topic  [ 5 posts ]
 lowe roughnecks
Post lowe roughnecks
there site says that they can handle a mudmotor.....can i put a 35GTR on the back of it without having to brace up the transom????
Sun Jan 31, 2010 5:21 pm
Post Re: lowe roughnecks
Are you buying one or already have one? What size boat you lookin at. Looks like the bigger boats are rated 50hp on up. Don't see why puttin a 35 mm on one would hurt anything.
If your looking to purchase one, why not look into getting a boat built specifically for a mm?
Sun Jan 31, 2010 7:43 pm
I have a 16x52 lowe roughneck with a 35 MB on the back with no additional bracing. If you are buying it new and can afford it go with a mud hull you won’t be sorry.
But the Lowe will work ok as well. You will lose durability and lose some speed.
1652 w/ MB Mini 35
Mon Feb 01, 2010 9:36 am
If you just want to save some cash, call Gator Tail, they have other hulls they stock (can't remember brand) that they have made for the GT motors.
Mon Feb 01, 2010 11:07 am
If you are buying new, look at another boat made for a MM. The roughneck is a good boat if you plan on a 40-60 OB, but they under perform with MM with any kind of load. The transoms are okay, just watch for cracking weld with a MM over time. We have seen a number with cracked welds after a couple of seasons of hitting stuff and trailering. Your biggest concern should be performance, i.e. they plow water with anything over a two man load and any gear where a good MM hull will carry 3-5 guys and plane with no issues with the same MM on the back.
PW
Paul V. Willging - Owner
Phowler Boat Company
Illowa Marine
Mon Feb 01, 2010 11:09 am
