It is currently Thu Dec 25, 2025 1:50 am
[ 7 posts ] |
2014 pd manual reverse has a jerk in it
Riverrats1
Just got a 2014 36 pd short shaft put on my 06 pd boat. The last motor a 06 36 would randomly jerk in your hand and feel like it was missing. I thaught it was worn out. On my brand new 0 hour motor it does the same thing. It feels like you are lightly bumping a stump every 10 to 20 seconds in open water. Also my boat will plane out good, all of a sudden the handle will have a little pull to it and the nose will plow for a couple seconds the plane back out again repeatadly. Please help very frustrated!!!!
| Fri Jul 25, 2014 11:37 am |
Quack Stackin
Joined: Mon Feb 14, 2011 6:07 pm Posts: 759 Location: NE ALABAMA
 Re: 2014 pd manual reverse has a jerk in it
does it happened when trimmed down well below the surface? the small jerk happens on my mudbuddy and its just the nature of the briggs I believe
| Fri Jul 25, 2014 11:53 am |
Riverrats1
Trimming it in normal running position or below the surface it does it. It may be normall but I know the nose plowing then lifting back up is not normall. I'm going to bend the trim tab up a little bit and see how that does.
| Fri Jul 25, 2014 12:07 pm |
Riverrats1
Talked to prodrive and believe we've got it narrowd down to a boat hull issue. Thanks
| Fri Jul 25, 2014 3:19 pm |
Swamp Wader
I was gonna say you may have some bad hooks in your hull. What the bottom look like
| Sun Jul 27, 2014 11:59 am |
OwenDickeson
Hooked boat.
| Sun Jul 27, 2014 1:39 pm |
bayouboy
If its doing the same thing with 2 different motor than that only leave the boat.
| Sun Jul 27, 2014 6:11 pm |
[ 7 posts ] |
