It is currently Tue Dec 16, 2025 8:47 am
Reply to topic  [ 7 posts ]
 2014 pd manual reverse has a jerk in it
Post 2014 pd manual reverse has a jerk in it
Just got a 2014 36 pd short shaft put on my 06 pd boat. The last motor a 06 36 would randomly jerk in your hand and feel like it was missing. I thaught it was worn out. On my brand new 0 hour motor it does the same thing. It feels like you are lightly bumping a stump every 10 to 20 seconds in open water. Also my boat will plane out good, all of a sudden the handle will have a little pull to it and the nose will plow for a couple seconds the plane back out again repeatadly. Please help very frustrated!!!!
Fri Jul 25, 2014 11:37 am
Post Re: 2014 pd manual reverse has a jerk in it
does it happened when trimmed down well below the surface? the small jerk happens on my mudbuddy and its just the nature of the briggs I believe
Fri Jul 25, 2014 11:53 am
Trimming it in normal running position or below the surface it does it. It may be normall but I know the nose plowing then lifting back up is not normall. I'm going to bend the trim tab up a little bit and see how that does.
Fri Jul 25, 2014 12:07 pm
Talked to prodrive and believe we've got it narrowd down to a boat hull issue. Thanks
Fri Jul 25, 2014 3:19 pm
I was gonna say you may have some bad hooks in your hull. What the bottom look like
Sun Jul 27, 2014 11:59 am
Hooked boat.
Sun Jul 27, 2014 1:39 pm
If its doing the same thing with 2 different motor than that only leave the boat.
Sun Jul 27, 2014 6:11 pm
