It is currently Sat May 10, 2025 2:48 am
Reply to topic  [ 10 posts ]
 Grass on prop
Post Grass on prop
My mud motor has a 1/4” gap from the prop to the bushing. Grass always gets tangled up in that area. Always have to clear it out.
Is that normal ? Should I add a washer to fill the gap ?
Sun Nov 25, 2012 9:16 pm
Post Re: Grass on prop
Just put it in reverse , then back in forward. It will clean it out
Sun Nov 25, 2012 9:18 pm
does it wrap up in there and then clog up the prop? I had a similar problem with my LT, took som 1/8" plate and welded it to the skeg so it had very little clearance to that gap, it acted like a shear and cut anything that started to get wrapped up.
Thu Nov 29, 2012 9:09 am
Yes. I was going to add an oversized washer and sharpen the edges so it would cut it but I think your idea will work better.
Thu Nov 29, 2012 10:32 am
"There's nothing a duck hunter hates more than another duck hunter"
Custom 17x48 with a new Gen III Prodrive.
Thu Nov 29, 2012 11:10 am
Sun Dec 09, 2012 5:01 pm
23gtr crossover Mikuni
Sun Dec 09, 2012 5:47 pm
New Member
IU am having the same problem. It sounds like most say the skeg should be closer to the prop. I guess I will try making a new skeg and seeing how that does with the grass.
Sun Nov 20, 2016 8:35 pm
A little grass there shouldn't affect anything, and reversing should clear most of it. Now nylon fishing line or trot line string that with do a number on your seals!!! Get it out asap!!!
Fri Nov 25, 2016 9:34 am
Fri Nov 25, 2016 9:44 am
Users browsing this forum: No registered users and 153 guests
